| SWT property editor(2) [message #66141] |
Fri, 20 October 2006 05:37   |
Eclipse User  |
This is continued on from previous thread:
 http://dev.eclipse.org/newslists/news.eclipse.modeling.gmf/m sg01605.html
I want to use a SWT display to view and edit the properties of my model
elements, accessed through double-clicking the elements (as described in
other threads).
I've changed the elements InfoEditPart, this calls the new
OpenEditorEditPolicy when double clicked (OPEN_ROLE):
protected void createDefaultEditPolicies() {
	        super.createDefaultEditPolicies();
	        installEditPolicy(
	            EditPolicyRoles.OPEN_ROLE,
	            new OpenEditorEditPolicy ());
The OpenEditorEditPolicy extends the OpenEditPolicy as described in:
 http://dev.eclipse.org/newslists/news.eclipse.technology.gmf /msg03767.html
I've added comments, there are some parts I'm unsure of, what I'd like to
happen first is just to open a blank SWT with nothing on it. Next step, to
have it display properties of the emlement, Finally, be able to edit
properties.
The second System.out.println works, so I know it's doing something, but
how do I get the SWT dialog to come up? Thanks.
public class OpenEditorEditPolicy extends OpenEditPolicy {
    protected Command getOpenCommand(Request request) { //request is the
location of the mouse pointer - what is command used for?
    	EditPart targetEditPart = getTargetEditPart(request); //the Editpart
is told the location of the mouse pointer
    	if (targetEditPart instanceof IGraphicalEditPart) { //if the mouse
location is part of the model(IGraphicalEditPart???)
                    IGraphicalEditPart editPart =
(IGraphicalEditPart)targetEditPart; //model editpart is told mouse
location???
                    View view = editPart.getNotationView();
                    if (view !=null){
                            EObject element =
ViewUtil.resolveSemanticElement(view); //gets the element that is at the
location
                            if (element instanceof Diagram) { // if the
element is in the model
                                // open a blank SWT dialog
                                Display d = new Display();
            					Shell s = new Shell(d, SWT.CLOSE|SWT.RESIZE);
            					s.setSize(300, 300);
            					s.pack();
            					s.open();
            					System.out.println("Double click called"); // this never
gets printed
            					return new ICommandProxy(new
OpenDiagramCommand(element)); // don't know what this does
                            System.out.println("Double click called 2");
// this DOES get printed
         return null;
| Re: SWT property editor(2) [message #66310 is a reply to message #66141] |
Fri, 20 October 2006 07:46    |
Eclipse User  |
Guess, you didn't put notation.Diagram as you _semantic_ element, which is
NOT what usually people do. Hence, if (element instanceof Diagram) will
never be true. Check https://bugs.eclipse.org/bugs/show_bug.cgi?id=159479.
Artem
"Gaff" <conorgaff@hotmail.com> wrote in message
news:c8d3b02a693a2e2dfb95e2c3f633449b$1@www.eclipse.org...
> other threads).
> super.createDefaultEditPolicies(); installEditPolicy(
> EditPolicyRoles.OPEN_ROLE, new OpenEditorEditPolicy ());
> properties.
> public class OpenEditorEditPolicy extends OpenEditPolicy { protected
> Command getOpenCommand(Request request) { //request is the location of the
> Editpart is told the location of the mouse pointer
> mouse location is part of the model(IGraphicalEditPart???)
>    IGraphicalEditPart editPart = (IGraphicalEditPart)targetEditPart;
> //model editpart is told mouse location???
>                    View view = editPart.getNotationView(); if (view
> !=null){ EObject element = ViewUtil.resolveSemanticElement(view); //gets
> the element that is at the location
>                                    // open a blank SWT dialog    Display d
> = new Display();
>            s.pack();
>            s.open();  System.out.println("Double click called"); // this
> never gets printed
>            return new ICommandProxy(new OpenDiagramCommand(element)); //
>            } System.out.println("Double click called 2");  // this DOES
> get printed
>                    } }  return null; }
| Re: SWT property editor(2) [message #67623 is a reply to message #66401] |
Mon, 23 October 2006 06:41   |
Eclipse User  |
Well, it's not that simple, you know - if OpenDiagramCommand do not need
instanceof Diagram, there would be no check from the very beginning. Look at
OpenDiagramCommand#canExecute.
Hint - you don't need Open_Diagram_Command if you intend to open _SWT
Property Editor_ instead (as title of your post suggests).
> Also Bug reference doesn't exist.
Hm, the link works perfectly for me. Did you try looking up by bug number
(159479)?
Artem
news:899e54edf3638b75bd5c49303f7776f6$1@www.eclipse.org...
> No, didn't put notation.Diagram as sematic element.
> I removed the if statement completely:
> The code will now go as far as
> Which doesn't seem to do anything. What is the purpose of this line? I'm
> guessing it doesn't work same reason as described before.
FUDForum. Page generated in 0.04715 seconds
