Home » Eclipse Projects » Eclipse Platform » Views Article: getImageDescriptor throws NullPointerException
Views Article: getImageDescriptor throws NullPointerException [message #65986] Fri, 06 June 2003 21:04 Go to next message
Originally posted by: rohiteipe.hotmail.com
I was following the Article on Views
( http://www.eclipse.org/articles/viewArticle/ViewArticle2.htm l), and I ran
into a spot of trouble. Before I commented out this line:
addItemAction.setImageDescriptor(getImageDescriptor("add.gif "));
The call to getImageDescriptor(), was giving me a NullPointerException.
When I did comment it out, the view worked, I got a toolbar, and a menu,
and delete.gif for the menu bar buttons.
As far as the code in the article goes, createPartControl() calls a method
createActions(), which makes a call to getImageDescriptor() in the line
pasted above.
See below for the log entry, I think only the first few lines are relevant.
Any advice would be appreciated, Thanks in advance.
Rohit
!ENTRY org.eclipse.ui.workbench 4 2 Jun 06, 2003 15:53:24.526
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.ui.articles.views.WordView.getImageDescriptor(Wo rdView.java:218)
at org.eclipse.ui.articles.views.WordView.createActions(WordVie w.java:130)
org.eclipse.ui.articles.views.WordView.createPartControl(Wor dView.java:80)
at org.eclipse.ui.internal.PartPane$4.run(PartPane.java:138)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:867)
at org.eclipse.core.runtime.Platform.run(Platform.java:413)
at org.eclipse.ui.internal.PartPane.createChildControl(PartPane .java:134)
at org.eclipse.ui.internal.ViewPane.createChildControl(ViewPane .java:202)
at org.eclipse.ui.internal.PartPane.createControl(PartPane.java :183)
at org.eclipse.ui.internal.ViewPane.createControl(ViewPane.java :181)
org.eclipse.ui.internal.PartTabFolder.createPartTab(PartTabF older.java:251)
org.eclipse.ui.internal.PartTabFolder.replaceChild(PartTabFo lder.java:683)
at org.eclipse.ui.internal.PartTabFolder.replace(PartTabFolder. java:623)
org.eclipse.ui.internal.PerspectivePresentation.addPart(Pers pectivePresentation.java:189)
at org.eclipse.ui.internal.Perspective.showView(Perspective.jav a:1470)
org.eclipse.ui.internal.WorkbenchPage.busyShowView(Workbench Page.java:652)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:631)
at org.eclipse.ui.internal.WorkbenchPage$12.run(WorkbenchPage.j ava:2742)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:65)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:2739)
at org.eclipse.ui.internal.WorkbenchPage.showView(WorkbenchPage .java:2729)
at org.eclipse.ui.internal.ShowViewMenu.showOther(ShowViewMenu. java:173)
at org.eclipse.ui.internal.ShowViewMenu.access$2(ShowViewMenu.j ava:159)
at org.eclipse.ui.internal.ShowViewMenu$2.run(ShowViewMenu.java :47)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:841 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:456)
org.eclipse.jface.action.ActionContributionItem.handleWidget Event(ActionContributionItem.java:403)
org.eclipse.jface.action.ActionContributionItem.access$0(Act ionContributionItem.java:397)
org.eclipse.jface.action.ActionContributionItem$ActionListen er.handleEvent(ActionContributionItem.java:72)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:836)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1775)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1483)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1271)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1254)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.java:845)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:461)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
Re: Views Article: getImageDescriptor throws NullPointerException [message #68314 is a reply to message #65986] Mon, 09 June 2003 19:16 Go to previous messageGo to next message
Originally posted by: debbie_wilson.ca.ibm.com
I ran this example on I20030605 without difficulty. The add.gif image is
found under the icons directory of this plugin. Did you extract the entire
viewArticleSrc.zip to your plugins directory?
My steps to run this example were:
- from the Eclipse download page, extract I20030605 (or M1) to d:/I20030506
(I'm on Windows XP)
- from the article, extract viewArticleSrc.zip to
d:/I20030506/eclipse/plugins
- fire up Eclipse
- Window->Show View->Other->Article->Word View
- I could add and/or remove words in this view without trouble
There were no errors in my log file.
Does this help at all?
Deb
"Rohit Eipe" <rohiteipe@hotmail.com> wrote in message
news:bbqvkn$sog$1@rogue.oti.com...
> Hi
> pasted above.
relevant.
> Rohit
> !STACK 0
> java.lang.NullPointerException
> at
> at
> at
:867)
> at
> at
> at
ion.java:189)
> at
> at
> at
> at
tem.java:397)
> at
> at
a:845)
> at
> at
..java:25)
Re: Views Article: getImageDescriptor throws NullPointerException [message #68324 is a reply to message #68314] Mon, 09 June 2003 19:44 Go to previous messageGo to next message
> (I'm on Windows XP)
> - fire up Eclipse
> Deb
> > Hi
> > pasted above.
> relevant.
> > Rohit
> > !STACK 0
> > at
> > at
> > at
> :867)
> > at
> > at
> > at
> ion.java:189)
> > at
> > at
> > at
> > at
> tem.java:397)
> > at
> > at
> a:845)
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
> ..java:25)
Re: Views Article: getImageDescriptor throws NullPointerException [message #68368 is a reply to message #68314] Mon, 09 June 2003 20:04 Go to previous messageGo to next message
Well, I am running 2.1, maybe that's the problem, though I'd be surprised
if it was. Can you update/install Eclipse over a previous installation
without losing all your work?
The add.gif was in the org.articles.ui.views folder of my workspace
folder. I moved it to the /plugins/org.articles.ui.views/icons/*.gif, and
that still didn't work. Ditto for delete.gif. I tried moving to
/plugins/icons/*.gif and that didn't work. I tried moving to
/plugins/*.gif and that didn't work. I tried
plugins/org.articles.ui.views/*.gif and that didn't work :-(
I didn't extract all of the code, though I did have to copy some files
from there. For the most part, I was just following along with the
article, so that I would understand things for myself.
The error message that comes up, if it helps, is
'Unable to create part view' : in a window, and then ..
'An error has occurred when creating this view' : in the view itself.
.. and the buttons don't show up. As I said, if I comment out the lines
mentioned in my original post, I get all the functionality, I was just
wondering about getting the +++ and X images to show up too. In their
places, I get little red squares.
I appreciate your help, thanks :-)
> (I'm on Windows XP)
> - fire up Eclipse
> Deb
> > Hi
> > pasted above.
> relevant.
> > Rohit
> > !STACK 0
> > at
> > at
> > at
> :867)
> > at
> > at
> > at
> ion.java:189)
> > at
> > at
> > at
> > at
> tem.java:397)
> > at
> > at
> a:845)
> > at
> > at
> ..java:25)
Re: Views Article: getImageDescriptor throws NullPointerException [message #71074 is a reply to message #68368] Wed, 11 June 2003 16:06 Go to previous message
I tried this with 2.1 and it works fine.
Is it possible for you to remove this particular project
(org.eclipse.ui.articles.views) and re-install it from the zip file? That
way we are starting from a common point.
The code to look for the icons happens in WorkView.getImageDescriptor(...).
It will look in a directory 'icons' under the directory for this plugin -
<workspace>/eclipse/plugins/org.eclipse.ui.articles.views/icons
Deb
news:bc2p8h$uka$1@rogue.oti.com...
> Hi
is
entire
d:/I20030506
> > (I'm on Windows XP)
> > - fire up Eclipse
> > Deb
> > > Hi
ran
menu,
> > > and I could add and delete items, but I couldn't see the images
method
line
> > > pasted above.
> > relevant.
> > > Rohit
> > > !STACK 0
> > > at
> > > at
> > > at
> > > at
> > :867)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > ion.java:189)
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > > at
> > tem.java:397)
> > > at
> > > at
> > > at
> > a:845)
> > > at
> > > at
> > ..java:25)
Previous Topic:HElp!!! big pb with plugin.xml
Next Topic:Build Eclipse project without starting IDE
Current Time: Thu Dec 26 23:12:45 GMT 2024
Powered by FUDForum. Page generated in 0.03905 seconds
