Home » Archived » Memory Analyzer (MAT) » JVM Terminates immediately under Mac OS X w/ J2SE 6.0
JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #5877] Wed, 29 October 2008 00:53 Go to next message
I tried MAT under J2SE 5.0 on Mac OS X 10.5, but when I switch the current
JDK to J2SE 6.0, it no longer functions. Upon launch it will terminate
immediately with the Message "JVM Terminated ... exit code = -1".
Could someone provide any advice to resolve this or possibly tell me how I
can configure it to refer to a Java installation (just so I can get it
working again).
Thanks!
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #5895 is a reply to message #5877] Wed, 29 October 2008 05:18 Go to previous messageGo to next message
I found this in the Eclipse documentation:
> SWT cannot be used with OS X JRE version 1.6 (Mac OSX only)
> OS X JRE version 1.6 assumes that pointers have a size of 64 bits,
> but SWT's Carbon port only uses 32-bit pointers, so SWT and Eclipse
> cannot be used with OS X JRE version 1.6. The workaround is to use
> an earlier supported version of the OS X JRE.
To use an earlier version, check out the Mac OS X chapter here:
http://help.eclipse.org/ganymede/topic/org.eclipse.platform. doc.user/tasks/running_eclipse.htm
E.g. add a "-vm path/to/vm/bin" to the Contents/MacOS/MemoryAnalyzer.ini
file.
Let me know if this helps.
Andreas.
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #5970 is a reply to message #5895] Wed, 29 October 2008 14:28 Go to previous messageGo to next message
I can't find a Content/MacOS directory *or* a MemoryAnalyzer.ini file in
the MAT folder.
Should I create one? If so: where?
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #6374 is a reply to message #5970] Thu, 30 October 2008 04:00 Go to previous messageGo to next message
> the MAT folder.
Applications under MacOS are packaged into a folder. When using Finder,
right-click on MemoryAnalyzer and select "Show Package Content". Then you
should see the Content/MacOS directory.
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #6392 is a reply to message #6374] Thu, 30 October 2008 04:44 Go to previous messageGo to next message
Ahh, that makes sense (as you probably noticed I am new to developing on
MacOS).
So I modified MemoryAnalyzer.ini to match the following:
-vmargs
-Xmx1024m
-Dorg.eclipse.swt.internal.carbon.smallFonts
-XstartOnFirstThread
-vm /System/Library/Frameworks/JavaVM.framework/Versions/1.5
yet, when I launch the app, I still see the same error *except* I notice
that it shows the -vm argument I added (in a dump of all options) but
there appears to be some other component that is pointing to the default
VM location (but I could be interpreting this wrong).
At any rate, is it possible there is another initialization file I need to
change as well?
thanks
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #6449 is a reply to message #6392] Thu, 30 October 2008 05:28 Go to previous messageGo to next message
Hi Ryan,
I don't develop on Mac either and my MacBook sits at home right now...
> -vmargs
> -Xmx1024m
First, try putting it on two lines:
-vm
Then, then try adapting the path. At least on Windows, it needs to point
to the directory which contains the java.exe file. E.g. it could be
something like .../Versions/1.5/bin or .../Versions/1.5/jre/bin or similar.
Andreas.
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #6504 is a reply to message #6449] Thu, 30 October 2008 14:28 Go to previous messageGo to next message
I am actually really liking the MacOS. What's frustrating is I am a big
fan of Eclipse MAT, but it is the only program I've been having trouble
with on my new Mac thus far.
> -vm
Just tried that, didn't appear to have an effect.
Tried this as well. No luck. The message that appears when I attempt to
run MAT is curious in that it shows the -vm ... option that I've added but
it also shows the -vm option again with the default JVM path. This is
what leads me to believe that the app has multiple files that contain this
path.
I'm presently not using any Windows emulation but it would be seriously
lame to be forced to given this is supposed to be a Java application.
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #6522 is a reply to message #6504] Thu, 30 October 2008 15:17 Go to previous messageGo to next message
Aha! I have it working now.
Take a look at:
http://stackoverflow.com/questions/245803/jvm-terminates-whe n-launching-eclipse-mat-on-mac-os-with-j2se-60
But thanks for telling about how Mac OS application are actually packages.
Not knowing this kept me from understanding the solution presented to me
in the thread that link above refers to.
Re: JVM Terminates immediately under Mac OS X w/ J2SE 6.0 [message #6558 is a reply to message #6522] Fri, 31 October 2008 03:46 Go to previous message
> Take a look at:
Thanks for solving this! On Windows, it is sufficient to add the VM
information to the MemoryAnalyzer.ini. But on Mac OS X it is not. Okay.
Previous Topic:Help understanding Heap Analysis
Next Topic:Stuck on 63%
Current Time: Thu Oct 16 07:04:51 EDT 2025
Powered by FUDForum. Page generated in 0.04612 seconds
