Home » Language IDEs » ServerTools (WTP) » Problems about sql editor and server explorer
Problems about sql editor and server explorer [message #65868] |
Mon, 17 January 2005 07:58 |
cheng Messages: 21 Registered: July 2009 |
Junior Member |
I am using sql editor in wtp,
I find when I save my sql file,all content are put between:
<SQLPage driver="" password="" url="" userid="">
<Statement><![CDATA[
and
]]]]><![CDATA[></Statement>
</SQLPage>
it's OK,
but when I close the editor,and open the file once again,
these are put into my file once again,
and all blank line are turned into two blank lines!!
Now,there are many copies of these text and blank lines in my file!
In server explorer,I am asked for password every time I reconnect
a database,I think the passwords can be saved.
And every time I create a new connection,I have to input the host,
jdbc driver path and so on,I think it will be convenient if
jdbc drivers for every database type are saved,and connection
urls are generated!
When I delete a server in server explorer,I have to close the view
and open it again,or it will be still there!
And I am wondering how to import and export my db servers
in server explorer!
Re: Problems about sql editor and server explorer [message #66673 is a reply to message #65868] |
Thu, 20 January 2005 19:59 |
Der Ping Chou Messages: 36 Registered: July 2009 |
Member |
A lists of good question you have there, my team member Sheila Sholars
will be able to address those related to SQLScrapbook.
We are refreshing our connection wizard contribution so that it would only
require the JDBC class name and URL. The reason that we don't generate
default URL is because that each JDBC driver URL varied from vendor to
vendor.
Sorry, we don't persist password, since from a different perspective,
other users treating it as a serious defect for security bleach.
Delete Server from Server Explorer view was a defect, it will be fix in
our next weeks' refresh.
Part of the value proposition about Open Source for RDB is a complete
SQLModel (UML/EMF), see following link under rdb for details:
http://www.eclipse.org/webtools/wst/components.xml
It also means other contributor will be able to walk through the model and
persist the contents of Server Explorer. You can find out code sample by
reviewing Server Explorer/Working off-line feature. We persist it to a EMF
model file.
Hope this help. Also in above link there is a tutorial doc, which will
assist you to explore our current contribution.
Der Ping
> and
> </SQLPage>
> it's OK,
> urls are generated!
> in server explorer!
Re: Problems about sql editor and server explorer [message #67018 is a reply to message #65868] |
Sat, 22 January 2005 18:11 |
Originally posted by: igor.shabalov.exadel.com
Cheng! Thank you for feedback, can you tell what version of WTP are you using?
Thank you again,
Igor Shabalov.
> and
> </SQLPage>
> it's OK,
> jdbc driver path and so on,I think it will be convenient if jdbc drivers
> for every database type are saved,and connection urls are generated!
> And I am wondering how to import and export my db servers in server
> explorer!
Re: Problems about sql editor and server explorer [message #67058 is a reply to message #67018] |
Mon, 24 January 2005 04:19 |
Junior Member |
I am using WTP 1.0M2 with wst and jst!
using?
> Thank you again,
> Igor Shabalov.
>> <?xml version="1.0" encoding="UTF-8"?>
>> and
>> </SQLPage>
>> it's OK,
>> explorer!
Re: Problems about sql editor and server explorer [message #67064 is a reply to message #66673] |
Mon, 24 January 2005 04:27 |
Junior Member |
But the password is in the xml file!
In server explorer,select "Open SQL Scracpbook" and the password
of the selected connected server will be stored in the xml file!
> vendor.
> model file.
> Der Ping
>> and
>> </SQLPage>
>> it's OK,
>> urls are generated!
>> in server explorer!
Current Time: Sat Oct 19 13:04:44 GMT 2024
Powered by FUDForum. Page generated in 0.04123 seconds
