"Trace into" in Eclipse [message #65847] |
Wed, 22 September 2004 14:15 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Samar.Hossam.web.de
Dear sir or madam,
I have some code in a jar file, and I need to trace into it. I managed to
decompile the jar file, remove the needed classes from the jar file and
re-jar it.
I included the new jar file in my project and the classes I needed as
sources are included in the src folder. When I start debugging, everything
goes fine until I trace into a method located in one of the classes I have
decompiled and excluded from the jar file.
The following happens: The cursor stands in a wrong position, i.e. not on
the method I have just traced into. I found out (using watches and some
heuristics) that the debugging process goes correctly, but the only
problem is that the cursor stands on the wrong line.
As a temporary solution, I added some lines (comments) in order to shift
eveything down and it worked. But after a while my method called another
one located above it. And again the cursor stood wrong. Now I cannot
change anything because my changes are relative to the first method.
Besides, this solution is rather stupied.
I would appreciate your help. Here's my e-mail address: Samar.Hossam@web.de
Regards, Samar
FUDForum. Page generated in 0.03350 seconds
