Problem with adding AspectJ nature to imported plugin [message #65828] |
Sun, 18 June 2006 01:42 |
Originally posted by: sbederml.gmail.com
I've imported the plugin org.eclipse.jdt.junit as binary project with
linked content. When I try to convert it to an AspectJ project using the
context menu (AspectJ tools -> Converto AspctJ Project), I receive the
following message:
"Operation cannot be performed because one or more resources belong to a
binary plug-in project that contains linked resources.
To be able to modify binary project resources, re-import it by copying
the content into the workspace".
The message is right, but I don't understand why. It worked for
org.eclise.search plugin.
What is the reason of the problem that causes AspectJ to fail?
Can I bypass it somehow, and still work with linked content?
Thank you in advance,
Michael
Re: Problem with adding AspectJ nature to imported plugin [message #65849 is a reply to message #65828] |
Sun, 18 June 2006 01:52 |
I think I've found the problem - plugin.xml and MANIFEST.MF are linked
in the plugin project, thus can't be changed.
Sorry to bother you,
Michael
Michael Beder wrote:
> following message:
> Michael
Re: Problem with adding AspectJ nature to imported plugin [message #594194 is a reply to message #65828] |
Michael
> following message:
> Michael
FUDForum. Page generated in 0.03117 seconds
