Home » Modeling » GMF (Graphical Modeling Framework) » Refreshing Decorations
Refreshing Decorations [message #65722] Thu, 19 October 2006 11:41 Go to next message
Originally posted by: john.campaner.s1.com
I have an action which converts a node on my diagram from a regular model
node to a shortcut.
This action relocates the underlying EMF model object to a different
resource then makes the annotation on the diagram view object to identify it
as a shortcut (in the same way the create shortcut action does).
Everything works great except I have to close the diagram and reopen it to
see the shortcut decoration showup on the node which has been converted.
Any suggestions on how I can force the redecoration of a node? I tried
refresh, activating, deactivating then activating again. None of that
worked.
John
Re: Refreshing Decorations [message #65744 is a reply to message #65722] Thu, 19 October 2006 13:02 Go to previous messageGo to next message
Hello John,
Can you put a breakpoint into the generated ShortcutsDecoratorProvider and
ensure that corresponding methods will be called after your attempts to reefresh
editor + required annotation was created correctly on the correct instance
of View.
Alex Shatalin
Re: Refreshing Decorations [message #65887 is a reply to message #65744] Thu, 19 October 2006 17:35 Go to previous messageGo to next message
I set the breakpoints as requrested.
I'm not too experienced with GMF but what it looks like the issue may be
that the shortcuts decorator is not installed on the EditPart in question
(which makes total sense as the node was not a shortcut when it was
originally created...it only became a shortcut after creation).
Even if I somehow install the decorator, the refresh() method on Shortcuts
decorator says:
public void refresh() {
removeDecoration();
Which removes any decorations on the target
Any recommendation on how best to resolve these issues?
"Alex Shatalin" <vano@borland.com> wrote in message
news:cd695fb3122fb8c8c1c850464fbf@news.eclipse.org...
> Hello John,
> reefresh editor + required annotation was created correctly on the correct
> instance of View.
> Alex Shatalin
Re: Refreshing Decorations [message #66184 is a reply to message #65887] Fri, 20 October 2006 06:34 Go to previous message
Hello John,
If corresponding annotation was not found in view then probably refresh action
was called before the code installing an annotation. Yu can check it by putting
breakpoint in createDecorators method and into the code installing an annotation
and comparing id of the view inside your code and ShortcutsDecoratorProvider.
> Shortcuts decorator says:
> removeDecoration();
Decorations should be added later on. You can see them if you reopen the
diagram, isn't it? The same code will be executed there as well.
Alex Shatalin
Previous Topic:Re: how to add to an existing edit policy?
Next Topic:modeling a typed graph with gmf
Current Time: Thu Oct 16 03:38:27 EDT 2025
Powered by FUDForum. Page generated in 0.03908 seconds
