Re: Web Service installation Problem [message #65749 is a reply to message #65687] |
Sat, 15 January 2005 13:07 |
Originally posted by: davegabol.eircom.net
Hi Tim,
Several people have had this problem on various windoze platforms (including
myself). Generally a clean install of all the components into an new empty
directory does the trick. There is also apparently something called "eclipse
clean" (or perhaps "eclipse clear" I can't remember) which can be run on the
existing install and should fix it. I haven't tried that as I'd already got
it working with a clean install before I found out.
Dave.
"Tim Draper" <tdraper@novell.com> wrote in message
news:cs9o6g$qo8$1@www.eclipse.org...
> I am trying to install Eclipse on Windows 2000 with WTP. I am using the
> directions outlined in:
http://download.eclipse.org/webtools/downloads/drops/S-1.0M2 -200412230036/in
dex.html.
> I have tried to install a couple of times to make sure it wasn't user
> error.
> The install works except that I don't see the menu feature for Web
> Services. I have been looking at:
http://www.eclipse.org/webtools/initial-contribution/IBM/eva lGuides/WebServi
cesToolsEval.html?p=1.
> In section 3.3, it shows that a Web Service option should exist in the
> preferences. I don't see it in preferences or under File|new|other|web
> service.
> I do see XML as an option under preference and File|new|other.
> I must be missing a key plug-in.
> Any help will be appreciated.
> Thanks Tim
Re: Web Service installation Problem [message #65973 is a reply to message #65835] |
Tue, 18 January 2005 15:20 |
Originally posted by: tdraper.novell.com
Thanks for you help. I will wait for M3.
Tim
Lawrence Mandel wrote:
> The startup option Dave is referring to is -clean however there is nothing
> wrong with your install in this case. Web services tools are not included
> in milestone M2. They are slated for milestone M3. You can see the WTP
> milestone plan at
http://www.eclipse.org/webtools/development/planning/milesto ne_plan_1_0.html.
> The document you are looking at is an evaluation guide to the initial WTP
> contribution posted by IBM last summer for feedback from the community.
> This contribution was a trial or sneak peak of some of the tools IBM
> considered contributing to the WTP project.
> Stay tuned for M3.
> Lawrence
>>Hi Tim,
> (including
> empty
> "eclipse
> the
> got
>>Dave.
> dex.html.
>> error.
>> service.
>> Thanks Tim
FUDForum. Page generated in 0.02821 seconds
