WikiText preview [message #65674] |
Thu, 19 February 2009 14:48 |
Originally posted by: tbone13.gmx.de
I'm trying to use Mylyn WikiText in my little RCP-App.
I tried it in the IDE with a generic project and a file "test.textile"
und tried to start with a heading
h1. test
some text
(w/o the quotes)
For a second I can see a well formatted output in the preview editor
page. but after this second it looks like this:
"blank#test"
no more text or any fomatting.
Is it a bug or did I miss some configuration?
Thanks in advance
Grretings
Tobi
Re: WikiText preview [message #65763 is a reply to message #65674] |
Fri, 20 February 2009 11:10 |
Hello!
I have some addition to my previous post.
The HTML source of the preview is
<HTML>blank#test</HTML>
so I think there is a problem in the parser.
On the other hand I tried the Task editor with textile-comment and it
works well. the same when I export HTML from the textile file
Greetings
Tobi
Re: WikiText preview [message #65877 is a reply to message #65785] |
Tue, 24 February 2009 14:21 |
> Tobi,
> There's a great little example application that you can see if you
> install the WikiText projects into your workspace (see
> http://wiki.eclipse.org/index.php/Mylyn/Contributor_Referenc e#Workspace).
> The code demonstrates how to integrate WikiText parsing for display with
> a Browser widget as well as with the MarkupViewer.
> The class is org.eclipse.mylyn.wikitext.textile.core.Main and you can
> run it by right-clicking on the file in Eclipse and selecting Run
> As->Java Application
> If after looking at that code you still have problems please file a bug
> at Eclipse.org and attach the problem code.
> David
David,
I found my mistake. I used the Weekly Updatesites, Mylyn 3.1 and
WikiText 0.9.4. I don't know if it is a bug or version conflict with the
rest of my installation. back to Mylyn 3.0.2 and WikiText 0.9.0 all
works fine.
I tried your example, but I don't understand how to use the internal
MarkupProjection in this Editor.
Best regards!
Tobi
Re: WikiText preview [message #596395 is a reply to message #65674] |
Hello!
Greetings
Tobi
Re: WikiText preview [message #596433 is a reply to message #65785] |
> Tobi,
> David
David,
works fine.
Best regards!
Tobi
FUDForum. Page generated in 0.03952 seconds
