Home » Eclipse Projects » Mylyn » Mylyn without CVS support
Mylyn without CVS support [message #65652] Tue, 17 February 2009 22:47 Go to next message
Kim Sullivan is currently offline Kim SullivanFriend
Member
I'm trying to create a bare bones eclipse platform + mylyn + subclipse
install. Unfortunately, some parts of mylyn depend on the eclipse cvs
feature, which I don't want.
I wanted to ask which parts of mylyn depend on CVS? None the core parts
explicitly mention CVS. The new update manager makes it hard to find out
what depends on what (and once something is downloaded, there's no
apparent way to get rid of the files if you uninstall the plugin).
Or is it a dependency, because the CVS plugin implements a large part of
the eclipse team functionality?
Kim
Re: Mylyn without CVS support [message #66420 is a reply to message #65652] Thu, 12 March 2009 08:00 Go to previous message
Steffen Pingel is currently offline Steffen PingelFriend
The org.eclipse.mylyn.team-feature has been decoupled from cvs for Mylyn
3.0:
191793: [api] remove coupling from to ..mylyn.team.ui to
org.eclipse.team.cvs
https://bugs.eclipse.org/bugs/show_bug.cgi?id=191793
The team support can be installed without cvs. If you do not consume the
org.eclipse.mylyn.ide-feature which includes Mylyn's cvs integration you
should not require cvs in your distribution.
Steffen
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Mylyn without CVS support [message #596673 is a reply to message #65652] Thu, 12 March 2009 08:00 Go to previous message
3.0:
Steffen
Steffen Pingel
Previous Topic:parseHtmlError when I call postTaskData() on Bugzilla Connector
Next Topic:WikiText preview
Current Time: Fri Jan 03 03:12:03 GMT 2025
Powered by FUDForum. Page generated in 0.03214 seconds
