How to specify file format [message #65607] |
Wed, 19 February 2003 09:42 |
Originally posted by: celine.mortelette.atosorigin.com
In order to build a graph, the user has to create a file with xxx extension
like test.xxx
How can I specify the file format ? I want it to be an xml file for example
Thanks for any answer.
Re: How to specify file format [message #65957 is a reply to message #65607] |
Fri, 21 February 2003 11:36 |
Originally posted by: beneyal.hotmaul.com
> like test.xxx
You don't have to specify the file format. After saving your graph into
the file in an XML format (by using a PrintWriter object for example), you
can use any XML reader (like Sun's SAX for example) to read your saved XML
tags.
Re: How to specify file format [message #66128 is a reply to message #66048] |
Fri, 21 February 2003 18:47 |
Mapping a graph element (Figure, I assume) to an XML tag is the job of you
application. Specifically, your EditPart serves as a "mini" content
provider/label provider, if you are familiar with JFace.
GEF is model neutral, so we can't begin to know how to map the model into
figures.
"C
FUDForum. Page generated in 0.02760 seconds
