Home » Eclipse Projects » GEF » How to specify file format
How to specify file format [message #65607] Wed, 19 February 2003 04:42 Go to next message
Originally posted by: celine.mortelette.atosorigin.com
In order to build a graph, the user has to create a file with xxx extension
like test.xxx
How can I specify the file format ? I want it to be an xml file for example
Thanks for any answer.
Re: How to specify file format [message #65957 is a reply to message #65607] Fri, 21 February 2003 06:36 Go to previous messageGo to next message
Originally posted by: beneyal.hotmaul.com
> like test.xxx
You don't have to specify the file format. After saving your graph into
the file in an XML format (by using a PrintWriter object for example), you
can use any XML reader (like Sun's SAX for example) to read your saved XML
tags.
Re: How to specify file format [message #66048 is a reply to message #65957] Fri, 21 February 2003 11:38 Go to previous messageGo to next message
Ok but how can I associate a graph element to an XML tag ?!
I don't find where I can do that in org.eclipse.gef.examples.logic example
Can you help me ?
"Eyal" <beneyal@hotmaul.com> a
Re: How to specify file format [message #66128 is a reply to message #66048] Fri, 21 February 2003 13:47 Go to previous message
Mapping a graph element (Figure, I assume) to an XML tag is the job of you
application. Specifically, your EditPart serves as a "mini" content
provider/label provider, if you are familiar with JFace.
GEF is model neutral, so we can't begin to know how to map the model into
figures.
"C
Previous Topic:Background Color for a Label
Next Topic:M5, GEF and Mac OS X
Current Time: Fri Apr 25 21:21:56 EDT 2025
Powered by FUDForum. Page generated in 0.02554 seconds
