Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo: Objects are not added to resource.contents if fetch="subselect" for collection
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65619 is a reply to message #65598] |
Wed, 27 December 2006 13:10 |
Ilya Klyuchnikov Messages: 74 Registered: July 2009 |
Member |
Hi Martin
I suppose that these details help you to understand problem:
This is stack trace:
Thread [main] (Suspended (breakpoint at line 366 in
AbstractPersistentCollection))
PersistentBag(AbstractPersistentCollection).setInitialized() line: 366
PersistentBag(AbstractPersistentCollection).afterInitialize( ) line: 319
PersistentBag(AbstractPersistentCollection).endRead() line: 315
CollectionLoadContext.endLoadingCollection(CollectionLoadCon text$LoadingCollectionEntry,
CollectionPersister, EntityMode) line: 183
CollectionLoadContext.endLoadingCollections(CollectionPersis ter, List,
EntityMode) line: 268
Object, SessionImplementor) line: 249
SubselectOneToManyLoader(Loader).endCollectionLoad(Object,
SessionImplementor, CollectionPersister) line: 866
SubselectOneToManyLoader(Loader).initializeEntitiesAndCollec tions(List,
Object, SessionImplementor, boolean) line: 853
SubselectOneToManyLoader(Loader).doQuery(SessionImplementor,
QueryParameters, boolean) line: 717
SubselectOneToManyLoader(Loader).doQueryAndInitializeNonLazy Collections(SessionImplementor,
QueryParameters, boolean) line: 224
SubselectOneToManyLoader(Loader).loadCollectionSubselect(Ses sionImplementor,
Serializable[], Object[], Type[], Map, Type) line: 1990
SubselectOneToManyLoader.initialize(Serializable, SessionImplementor)
line: 58
OneToManyPersister(AbstractCollectionPersister).initialize(S erializable,
SessionImplementor) line: 565
DefaultInitializeCollectionEventListener.onInitializeCollect ion(InitializeCollectionEvent)
line: 60
SessionImpl.initializeCollection(PersistentCollection, boolean) line: 1716
PersistentBag(AbstractPersistentCollection).initialize(boole an) line: 344
PersistentBag(AbstractPersistentCollection).read() line: 86
PersistentBag.toArray() line: 257
HibernatePersistableEList.doLoad() line: 106
HibernatePersistableEList(PersistableEList).load() line: 187
HibernatePersistableEList(PersistableEList).delegateSize() line: 395
HibernatePersistableEList(DelegatingEList).size() line: 214
DelegatingEList$EIterator.hasNext() line: 1000
DeploymentEnvironmentItemProvider(ItemProviderAdapter).getCh ildren(Object)
line: 339
DeploymentEnvironmentItemProvider(ItemProviderAdapter).hasCh ildren(Object)
line: 380
As you see activity begins with: HibernatePersistableEList.doLoad()
line: 106
and PersistentBag is marked as initialized BUT: request was passed to
EXACTLY ONE HibernatePersistableEList - so after PersistentBag
corresponding to THIS HibernatePersistableEList was loaded all objects
contained in PersistentBag are added to resource - it's OK.
PROBLEM:
Actually in my example THREE PersistentBag were loaded - cause three
object with such lazy collections are already loaded - try to
investigate org.hibernate.engine.endLoadingCollections() method - it has
following code:
final int count = (resultSetCollections == null) ? 0 :
resultSetCollections.size();
if ( log.isDebugEnabled() ) {
log.debug( count + " collections were found in result set for role: "
+ persister.getRole() );
//now finish them
for ( int i = 0; i < count; i++ ) {
LoadingCollectionEntry lce = (LoadingCollectionEntry)
resultSetCollections.get(i);
endLoadingCollection(lce, persister, em);
log.debug( count + " collections initialized for role: " +
In my example count = 3. So THREE PersistentBags were loaded - it
happened because my association has fetch="subselect".
So THREE PersistentBags were were marked as initialized but ONLY object
from ONE OF THEM were added to contents of resource.
Why other were not added?
Answer is simple:
Method doLoad() was not called for two other HibernatePersistableEList.
Adding objects to resource.contents() is in this method. Why was notthis
method called to two other list? Cause it is called only if isLoaded()
returns false.
BUT HOW is this method implemented for HibernatePersistableEList?
public boolean isLoaded() {
if (delegate instanceof AbstractPersistentCollection) {
if (((AbstractPersistentCollection) delegate).wasInitialized()) {
setIsLoaded(true);
// log.debug("Persistentlist already initialized, probably eagerly
loaded: " + getLogString());
return super.isLoaded();
So let me describe full chain of events:
There are THREE objects with lazy not loaded collections with
fetch="subselect". When one of HibernatePersistableELists is asked for
collection it force hibernate to load this collection via
Object[] objs = delegate.toArray(); // this forces the load
and adds objects to resource.
BUT during forcing of loading one delegate two other delegates were
loaded too - they were marked as initialized. So two other
HibernatePersistableELists will return isLoaded() = true because:
setIsLoaded(true);
So Teneo looses the moment when delegate is really initialized.
This happens when fetch="subselect". Details of how fetch="subselect"
works are in hibernate docs.
My proposals:
You can override setIsLoaded() in HibernatePersistableELists and check
that objects are added - then isLoaded needs to be implemented like:
if (isLoaded){
return true;
setIsLoaded(true);
Feel free to ask me for more details if my answer is not enough.
Ilya
Martin Taal wrote:
> I do not fully understand what happens here. Can you describe the
> case/example in which this occurs (automatically loading other such
> collections)? The hibernate behavior as you describe it is unfamiliar to
> me.
> gr. Martin
> Ilya Klyuchnikov wrote:
>> When I use HibernateResource with loading strategy addToContents then
>> all is OK until I have created association with fetch="subselect".
>> Sometimes objects that are inside these lazy collections are loaded
>> they are not added to resource.
>> As far as I understand it happens when I ask some objects from ONE
>> such collection BUT if there are any other such collections that are
>> not loaded Hibernate can load all such collections. And fact of
>> loading of other collections are not caught by Teneo.
>> Is this a bug?
>> Thanks
>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65639 is a reply to message #65619] |
Wed, 27 December 2006 13:13 |
Member |
Sorry - I misprinted method name where ALL INTERESTING happens:
org.hibernate.engine.CollectionLoadContext.endLoadingCollect ions()
instead of org.hibernate.engine.endLoadingCollections()
Ilya
> Hi Martin
> 366
> 319
> List, EntityMode) line: 268
> SessionImplementor) line: 58
> line: 60
> line: 1716
> line: 344
> line: 339
> line: 380
> line: 106
> PROBLEM:
> following code:
> for role: " + persister.getRole() );
> //now finish them
> Answer is simple:
> returns false.
> setIsLoaded(true);
> probably eagerly loaded: " + getLogString());
> setIsLoaded(true);
> My proposals:
> if (isLoaded){
> return true;
> setIsLoaded(true);
> Ilya
>> to me.
>> gr. Martin
>>> Is this a bug?
>>> Thanks
>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65661 is a reply to message #65639] |
Wed, 27 December 2006 13:48 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Ilya,
Yes the solution is in the isLoaded method. If the underlying hibernate collection is already
loaded/initialized while isLoaded=false then the children need to be added to the resource (calling
doLoad with some extra handling should work).
Are the automatically loaded collections eager or lazy?
gr. Martin
> Ilya
>> Hi Martin
>> 366
>> 319 PersistentBag(AbstractPersistentCollection).endRead() line:
>> 315
>> line: 58
>> line: 60 SessionImpl.initializeCollection(PersistentCollection,
>> boolean) line: 1716
>> 344 PersistentBag(AbstractPersistentCollection).read() line:
>> 86 PersistentBag.toArray() line: 257
>> line: 339
>> line: 380 As you see activity begins with:
>> PROBLEM:
>> has following code:
>> //now finish them
>> object from ONE OF THEM were added to contents of resource.
>> Answer is simple:
>> HibernatePersistableEList. Adding objects to resource.contents() is in
>> this method. Why was notthis method called to two other list? Cause it
>> is called only if isLoaded() returns false.
>> setIsLoaded(true);
>> setIsLoaded(true);
>> My proposals:
>> if (isLoaded){
>> return true;
>> setIsLoaded(true);
>> Ilya
>>> to me.
>>> gr. Martin
>>>> then all is OK until I have created association with fetch="subselect".
>>>> Is this a bug?
>>>> Thanks
>>>> Ilya
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65683 is a reply to message #65661] |
Wed, 27 December 2006 13:54 |
Member |
In my example lazy="true".
BTW, if there are collections with lazy="false" then during resource
loading objects in such collections are not added to resource.
Martin Taal wrote:
> Hi Ilya,
> collection is already loaded/initialized while isLoaded=false then the
> children need to be added to the resource (calling doLoad with some
> gr. Martin
>> Ilya
>>> Hi Martin
>>> 366
>>> 315
>>> line: 58
>>> boolean) line: 1716
>>> 395 HibernatePersistableEList(DelegatingEList).size() line:
>>> 214 DelegatingEList$EIterator.hasNext() line: 1000
>>> line: 339
>>> objects contained in PersistentBag are added to resource - it's OK.
>>> PROBLEM:
>>> has following code:
>>> //now finish them
>>> Answer is simple:
>>> in this method. Why was notthis method called to two other list?
>>> Cause it is called only if isLoaded() returns false.
>>> setIsLoaded(true);
>>> for collection it force hibernate to load this collection via
>>> setIsLoaded(true);
>>> My proposals:
>>> check that objects are added - then isLoaded needs to be implemented
>>> like:
>>> if (isLoaded){
>>> return true;
>>> setIsLoaded(true);
>>> Ilya
>>>> unfamiliar to me.
>>>> gr. Martin
>>>>> fetch="subselect".
>>>>> are not loaded Hibernate can load all such collections. And fact of
>>>>> Is this a bug?
>>>>> Thanks
>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65705 is a reply to message #65683] |
Wed, 27 December 2006 14:10 |
Yes for eagerly loaded lists I understand the issue. What I don't understand is why the lazy loaded
collections are loaded (automatically). You say:
What do you mean?
gr. Martin
> Martin Taal wrote:
>> Hi Ilya,
>> hibernate collection is already loaded/initialized while
>> (calling doLoad with some extra handling should work).
>> gr. Martin
>>> Ilya
>>>> Hi Martin
>>>> 366
>>>> line: 315
>>>> line: 60
>>>> line: 1716
>>>> line: 344 PersistentBag(AbstractPersistentCollection).read()
>>>> line: 86 PersistentBag.toArray() line: 257
>>>> line: 339
>>>> to EXACTLY ONE HibernatePersistableEList - so after PersistentBag
>>>> PROBLEM:
>>>> has following code:
>>>> set for role: " + persister.getRole() );
>>>> //now finish them
>>>> Answer is simple:
>>>> setIsLoaded(true);
>>>> setIsLoaded(true);
>>>> fetch="subselect" works are in hibernate docs.
>>>> My proposals:
>>>> like:
>>>> if (isLoaded){
>>>> return true;
>>>> setIsLoaded(true);
>>>> Ilya
>>>>> unfamiliar to me.
>>>>> gr. Martin
>>>>>> fetch="subselect".
>>>>>> loaded they are not added to resource.
>>>>>> of loading of other collections are not caught by Teneo.
>>>>>> Is this a bug?
>>>>>> Thanks
>>>>>> Ilya
The Netherlands
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65752 is a reply to message #65705] |
Wed, 27 December 2006 14:25 |
Member |
The reason that fetch="subselect":
With fetch="subselect" Hibernate loads ALL such collections on demand.
In my example when I ask DeploymentEnvironment.getDomains() Hibernate
generates such query:
Hibernate: select domain0_.`environment_id` as environm6_1_,
domain0_.`id` as id1_1_, domain0_.`id` as id1_21_0_, domain0_.e_version
as e3_21_0_, domain0_.`name` as name4_21_0_, domain0_.`modified` as
modified5_21_0_, domain0_.`environment_id` as environm6_21_0_ from
`domain` domain0_ where domain0_.`environment_id` in (select
deployment1_.`id` from environment_deploys deploysto0_ left outer join
`environment` deployment1_ on deploysto0_.`from_id`=deployment1_.`id`
where deploysto0_.`to_id`=?)
Put attentions to where domain0_.`environment_id` in ...
So this is a feature of Hibernate:
If there are some not loaded collection corresponding to the same
association (DeploymentEnvironment.domains in my example) having
fetch="subselect" and client ask ONE of these collections to be loaded
then Hibernate loads ALL collections. You can see this logic in
AbstractCollectionPersister class.
See
http://www.hibernate.org/hib_docs/v3/reference/en/html/perfo rmance.html#performance-fetching
for details.
Ilya
> understand is why the lazy loaded collections are loaded
> What do you mean?
> gr. Martin
>> Martin Taal wrote:
>>> Hi Ilya,
>>> gr. Martin
>>>> Ilya
>>>>> Hi Martin
>>>>> 366
>>>>> line: 315
>>>>> line: 60
>>>>> line: 1716
>>>>> line: 339
>>>>> PROBLEM:
>>>>> three object with such lazy collections are already loaded - try to
>>>>> it has following code:
>>>>> //now finish them
>>>>> Answer is simple:
>>>>> setIsLoaded(true);
>>>>> setIsLoaded(true);
>>>>> My proposals:
>>>>> implemented like:
>>>>> if (isLoaded){
>>>>> return true;
>>>>> setIsLoaded(true);
>>>>> Ilya
>>>>>> such collections)? The hibernate behavior as you describe it is
>>>>>> unfamiliar to me.
>>>>>> gr. Martin
>>>>>>> fetch="subselect".
>>>>>>> ONE such collection BUT if there are any other such collections
>>>>>>> that are not loaded Hibernate can load all such collections. And
>>>>>>> fact of loading of other collections are not caught by Teneo.
>>>>>>> Is this a bug?
>>>>>>> Thanks
>>>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65775 is a reply to message #65752] |
Wed, 27 December 2006 14:28 |
Member |
Quotes from hibernate documentaion
( http://www.hibernate.org/hib_docs/v3/reference/en/html/perfo rmance.html#performance-fetching):
Subselect fetching - a second SELECT is used to retrieve the associated
collections for ALL entities retrieved in a previous query or fetch.
Unless you explicitly disable lazy fetching by specifying lazy="false",
this second select will only be executed when you actually access the
association.
Ilya
> See
> for details.
> Ilya
>> three
>> What do you mean?
>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Ilya,
>>>> gr. Martin
>>>>> Ilya
>>>>>> Hi Martin
>>>>>> 366
>>>>>> line: 319
>>>>>> 315
>>>>>> line: 60
>>>>>> line: 1716
>>>>>> line: 339
>>>>>> PROBLEM:
>>>>>> to investigate org.hibernate.engine.endLoadingCollections() method
>>>>>> - it has following code:
>>>>>> //now finish them
>>>>>> Answer is simple:
>>>>>> is in this method. Why was notthis method called to two other
>>>>>> list? Cause it is called only if isLoaded() returns false.
>>>>>> setIsLoaded(true);
>>>>>> were loaded too - they were marked as initialized. So two other
>>>>>> setIsLoaded(true);
>>>>>> My proposals:
>>>>>> implemented like:
>>>>>> if (isLoaded){
>>>>>> return true;
>>>>>> setIsLoaded(true);
>>>>>> Ilya
>>>>>>> unfamiliar to me.
>>>>>>> gr. Martin
>>>>>>>> fetch="subselect".
>>>>>>>> Is this a bug?
>>>>>>>> Thanks
>>>>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65798 is a reply to message #65752] |
Okay, clear, I will commit a fix for this this evening. Are you able to test the cvs version or make
the change locally?
gr. Martin
> See
> for details.
> Ilya
>> three
>> What do you mean?
>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Ilya,
>>>> gr. Martin
>>>>> Ilya
>>>>>> Hi Martin
>>>>>> 366
>>>>>> line: 319
>>>>>> 315
>>>>>> line: 60
>>>>>> line: 1716
>>>>>> line: 339
>>>>>> PROBLEM:
>>>>>> //now finish them
>>>>>> Answer is simple:
>>>>>> setIsLoaded(true);
>>>>>> setIsLoaded(true);
>>>>>> My proposals:
>>>>>> implemented like:
>>>>>> if (isLoaded){
>>>>>> return true;
>>>>>> setIsLoaded(true);
>>>>>> Ilya
>>>>>>> unfamiliar to me.
>>>>>>> gr. Martin
>>>>>>>> fetch="subselect".
>>>>>>>> Is this a bug?
>>>>>>>> Thanks
>>>>>>>> Ilya
The Netherlands
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65822 is a reply to message #65798] |
Wed, 27 December 2006 15:24 |
Member |
Sorry Martin,
It is time consuming for me to build and test Teneo cvs version.
I think that I will be able to test your changes on Friday evening only.
Ilya
> test the cvs version or make the change locally?
> gr. Martin
>> domain0_.e_version as e3_21_0_, domain0_.`name` as name4_21_0_,
>> domain0_.`modified` as modified5_21_0_, domain0_.`environment_id` as
>> environm6_21_0_ from `domain` domain0_ where domain0_.`environment_id`
>> in (select deployment1_.`id` from environment_deploys deploysto0_ left
>> outer join `environment` deployment1_ on
>> deploysto0_.`from_id`=deployment1_.`id` where deploysto0_.`to_id`=?)
>> See
>> for details.
>> Ilya
>>> three
>>> What do you mean?
>>> gr. Martin
>>>> Martin Taal wrote:
>>>>> Hi Ilya,
>>>>> gr. Martin
>>>>>> Ilya
>>>>>>> Hi Martin
>>>>>>> line: 366
>>>>>>> line: 319
>>>>>>> 315
>>>>>>> line: 60
>>>>>>> line: 1716
>>>>>>> line: 344
>>>>>>> 187
>>>>>>> line: 339
>>>>>>> passed to EXACTLY ONE HibernatePersistableEList - so after
>>>>>>> PersistentBag corresponding to THIS HibernatePersistableEList was
>>>>>>> loaded all objects contained in PersistentBag are added to
>>>>>>> resource - it's OK.
>>>>>>> PROBLEM:
>>>>>>> method - it has following code:
>>>>>>> //now finish them
>>>>>>> Answer is simple:
>>>>>>> setIsLoaded(true);
>>>>>>> asked for collection it force hibernate to load this collection via
>>>>>>> setIsLoaded(true);
>>>>>>> My proposals:
>>>>>>> implemented like:
>>>>>>> if (isLoaded){
>>>>>>> return true;
>>>>>>> setIsLoaded(true);
>>>>>>> Ilya
>>>>>>>> the case/example in which this occurs (automatically loading
>>>>>>>> other such collections)? The hibernate behavior as you describe
>>>>>>>> it is unfamiliar to me.
>>>>>>>> gr. Martin
>>>>>>>>> addToContents then all is OK until I have created association
>>>>>>>>> And fact of loading of other collections are not caught by Teneo.
>>>>>>>>> Is this a bug?
>>>>>>>>> Thanks
>>>>>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #65977 is a reply to message #65822] |
Fri, 29 December 2006 08:19 |
Hi Ilya,
You can try the latest build here, that's easier then using the cvs version:
http://emft.eclipse.org/emft/downloads/index.php?project=ten eo&showAll=0&showMax=10&sortBy=date
gr. Martin
> Sorry Martin,
> Ilya
>> to test the cvs version or make the change locally?
>> gr. Martin
>>> domain0_.`environment_id` in (select deployment1_.`id` from
>>> environment_deploys deploysto0_ left outer join `environment`
>>> deployment1_ on deploysto0_.`from_id`=deployment1_.`id` where
>>> loaded then Hibernate loads ALL collections. You can see this logic
>>> in AbstractCollectionPersister class.
>>> See
>>> for details.
>>> Ilya
>>>> three
>>>> What do you mean?
>>>> gr. Martin
>>>>> resource loading objects in such collections are not added to
>>>>> resource.
>>>>> Martin Taal wrote:
>>>>>> Hi Ilya,
>>>>>> gr. Martin
>>>>>>> Ilya
>>>>>>>> Hi Martin
>>>>>>>> line: 366
>>>>>>>> line: 319
>>>>>>>> 315
>>>>>>>> line: 60
>>>>>>>> line: 1716
>>>>>>>> line: 344
>>>>>>>> 187
>>>>>>>> line: 214 DelegatingEList$EIterator.hasNext() line:
>>>>>>>> 1000
>>>>>>>> line: 339
>>>>>>>> was loaded all objects contained in PersistentBag are added to
>>>>>>>> resource - it's OK.
>>>>>>>> PROBLEM:
>>>>>>>> result set for role: " + persister.getRole() );
>>>>>>>> //now finish them
>>>>>>>> (LoadingCollectionEntry) resultSetCollections.get(i);
>>>>>>>> it happened because my association has fetch="subselect".
>>>>>>>> Answer is simple:
>>>>>>>> setIsLoaded(true);
>>>>>>>> initialized, probably eagerly loaded: " + getLogString());
>>>>>>>> setIsLoaded(true);
>>>>>>>> My proposals:
>>>>>>>> implemented like:
>>>>>>>> if (isLoaded){
>>>>>>>> return true;
>>>>>>>> setIsLoaded(true);
>>>>>>>> Ilya
>>>>>>>>> gr. Martin
>>>>>>>>>> collections that are not loaded Hibernate can load all such
>>>>>>>>>> collections. And fact of loading of other collections are not
>>>>>>>>>> caught by Teneo.
>>>>>>>>>> Is this a bug?
>>>>>>>>>> Thanks
>>>>>>>>>> Ilya
The Netherlands
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600267 is a reply to message #65598] |
Member |
Hi Martin
line: 58
line: 60
line: 339
line: 380
line: 106
PROBLEM:
following code:
//now finish them
Answer is simple:
returns false.
setIsLoaded(true);
setIsLoaded(true);
My proposals:
if (isLoaded){
return true;
setIsLoaded(true);
Ilya
> me.
> gr. Martin
>> Is this a bug?
>> Thanks
>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600275 is a reply to message #65619] |
Member |
Ilya
> Hi Martin
> 366
> 319
> line: 60
> line: 1716
> line: 344
> line: 339
> line: 380
> line: 106
> PROBLEM:
> following code:
> //now finish them
> Answer is simple:
> returns false.
> setIsLoaded(true);
> setIsLoaded(true);
> My proposals:
> if (isLoaded){
> return true;
> setIsLoaded(true);
> Ilya
>> to me.
>> gr. Martin
>>> Is this a bug?
>>> Thanks
>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600281 is a reply to message #65639] |
Hi Ilya,
gr. Martin
> Ilya
>> Hi Martin
>> 366
>> 315
>> line: 58
>> boolean) line: 1716
>> line: 339
>> PROBLEM:
>> has following code:
>> //now finish them
>> Answer is simple:
>> setIsLoaded(true);
>> setIsLoaded(true);
>> My proposals:
>> if (isLoaded){
>> return true;
>> setIsLoaded(true);
>> Ilya
>>> to me.
>>> gr. Martin
>>>> Is this a bug?
>>>> Thanks
>>>> Ilya
The Netherlands
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600287 is a reply to message #65661] |
Member |
Martin Taal wrote:
> Hi Ilya,
> gr. Martin
>> Ilya
>>> Hi Martin
>>> 366
>>> 315
>>> line: 58
>>> boolean) line: 1716
>>> line: 339
>>> PROBLEM:
>>> has following code:
>>> //now finish them
>>> Answer is simple:
>>> setIsLoaded(true);
>>> setIsLoaded(true);
>>> My proposals:
>>> like:
>>> if (isLoaded){
>>> return true;
>>> setIsLoaded(true);
>>> Ilya
>>>> unfamiliar to me.
>>>> gr. Martin
>>>>> fetch="subselect".
>>>>> Is this a bug?
>>>>> Thanks
>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600292 is a reply to message #65683] |
What do you mean?
gr. Martin
> Martin Taal wrote:
>> Hi Ilya,
>> gr. Martin
>>> Ilya
>>>> Hi Martin
>>>> 366
>>>> line: 315
>>>> line: 60
>>>> line: 1716
>>>> line: 339
>>>> PROBLEM:
>>>> has following code:
>>>> //now finish them
>>>> Answer is simple:
>>>> setIsLoaded(true);
>>>> setIsLoaded(true);
>>>> My proposals:
>>>> like:
>>>> if (isLoaded){
>>>> return true;
>>>> setIsLoaded(true);
>>>> Ilya
>>>>> unfamiliar to me.
>>>>> gr. Martin
>>>>>> fetch="subselect".
>>>>>> Is this a bug?
>>>>>> Thanks
>>>>>> Ilya
The Netherlands
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600322 is a reply to message #65705] |
Member |
See
for details.
Ilya
> What do you mean?
> gr. Martin
>> Martin Taal wrote:
>>> Hi Ilya,
>>> gr. Martin
>>>> Ilya
>>>>> Hi Martin
>>>>> 366
>>>>> line: 315
>>>>> line: 60
>>>>> line: 1716
>>>>> line: 339
>>>>> PROBLEM:
>>>>> //now finish them
>>>>> Answer is simple:
>>>>> setIsLoaded(true);
>>>>> setIsLoaded(true);
>>>>> My proposals:
>>>>> implemented like:
>>>>> if (isLoaded){
>>>>> return true;
>>>>> setIsLoaded(true);
>>>>> Ilya
>>>>>> unfamiliar to me.
>>>>>> gr. Martin
>>>>>>> fetch="subselect".
>>>>>>> Is this a bug?
>>>>>>> Thanks
>>>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600330 is a reply to message #65752] |
Member |
association.
Ilya
> See
> for details.
> Ilya
>> three
>> What do you mean?
>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Ilya,
>>>> gr. Martin
>>>>> Ilya
>>>>>> Hi Martin
>>>>>> 366
>>>>>> line: 319
>>>>>> 315
>>>>>> line: 60
>>>>>> line: 1716
>>>>>> line: 339
>>>>>> PROBLEM:
>>>>>> //now finish them
>>>>>> Answer is simple:
>>>>>> setIsLoaded(true);
>>>>>> setIsLoaded(true);
>>>>>> My proposals:
>>>>>> implemented like:
>>>>>> if (isLoaded){
>>>>>> return true;
>>>>>> setIsLoaded(true);
>>>>>> Ilya
>>>>>>> unfamiliar to me.
>>>>>>> gr. Martin
>>>>>>>> fetch="subselect".
>>>>>>>> Is this a bug?
>>>>>>>> Thanks
>>>>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600333 is a reply to message #65752] |
the change locally?
gr. Martin
> See
> for details.
> Ilya
>> three
>> What do you mean?
>> gr. Martin
>>> Martin Taal wrote:
>>>> Hi Ilya,
>>>> gr. Martin
>>>>> Ilya
>>>>>> Hi Martin
>>>>>> 366
>>>>>> line: 319
>>>>>> 315
>>>>>> line: 60
>>>>>> line: 1716
>>>>>> line: 339
>>>>>> PROBLEM:
>>>>>> //now finish them
>>>>>> Answer is simple:
>>>>>> setIsLoaded(true);
>>>>>> setIsLoaded(true);
>>>>>> My proposals:
>>>>>> implemented like:
>>>>>> if (isLoaded){
>>>>>> return true;
>>>>>> setIsLoaded(true);
>>>>>> Ilya
>>>>>>> unfamiliar to me.
>>>>>>> gr. Martin
>>>>>>>> fetch="subselect".
>>>>>>>> Is this a bug?
>>>>>>>> Thanks
>>>>>>>> Ilya
The Netherlands
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600343 is a reply to message #65798] |
Member |
Sorry Martin,
Ilya
> gr. Martin
>> See
>> for details.
>> Ilya
>>> three
>>> What do you mean?
>>> gr. Martin
>>>> Martin Taal wrote:
>>>>> Hi Ilya,
>>>>> gr. Martin
>>>>>> Ilya
>>>>>>> Hi Martin
>>>>>>> line: 366
>>>>>>> line: 319
>>>>>>> 315
>>>>>>> line: 60
>>>>>>> line: 1716
>>>>>>> line: 344
>>>>>>> 187
>>>>>>> line: 339
>>>>>>> resource - it's OK.
>>>>>>> PROBLEM:
>>>>>>> //now finish them
>>>>>>> Answer is simple:
>>>>>>> setIsLoaded(true);
>>>>>>> setIsLoaded(true);
>>>>>>> My proposals:
>>>>>>> implemented like:
>>>>>>> if (isLoaded){
>>>>>>> return true;
>>>>>>> setIsLoaded(true);
>>>>>>> Ilya
>>>>>>>> gr. Martin
>>>>>>>>> Is this a bug?
>>>>>>>>> Thanks
>>>>>>>>> Ilya
Re: Teneo: Objects are not added to resource.contents if fetch="subselect" for collection [message #600400 is a reply to message #65822] |
Hi Ilya,
gr. Martin
> Sorry Martin,
> Ilya
>> gr. Martin
>>> See
>>> for details.
>>> Ilya
>>>> three
>>>> What do you mean?
>>>> gr. Martin
>>>>> resource.
>>>>> Martin Taal wrote:
>>>>>> Hi Ilya,
>>>>>> gr. Martin
>>>>>>> Ilya
>>>>>>>> Hi Martin
>>>>>>>> line: 366
>>>>>>>> line: 319
>>>>>>>> 315
>>>>>>>> line: 60
>>>>>>>> line: 1716
>>>>>>>> line: 344
>>>>>>>> 187
>>>>>>>> 1000
>>>>>>>> line: 339
>>>>>>>> resource - it's OK.
>>>>>>>> PROBLEM:
>>>>>>>> //now finish them
>>>>>>>> Answer is simple:
>>>>>>>> setIsLoaded(true);
>>>>>>>> setIsLoaded(true);
>>>>>>>> My proposals:
>>>>>>>> implemented like:
>>>>>>>> if (isLoaded){
>>>>>>>> return true;
>>>>>>>> setIsLoaded(true);
>>>>>>>> Ilya
>>>>>>>>> gr. Martin
>>>>>>>>>> caught by Teneo.
>>>>>>>>>> Is this a bug?
>>>>>>>>>> Thanks
>>>>>>>>>> Ilya
The Netherlands
Current Time: Sat Jul 27 17:16:52 GMT 2024
Powered by FUDForum. Page generated in 0.06933 seconds
