Home » Eclipse Projects » Eclipse Platform » set java vm for ant runner?
set java vm for ant runner? [message #65534] Fri, 06 June 2003 10:36 Go to next message
Originally posted by: no.spam.com
How do I set the java vm that the Ant runner runs under? For some
reason, mine keeps trying to run under a jre (rather than the jdk) which
is causing me headaches.
Dan
Re: set java vm for ant runner? [message #65845 is a reply to message #65534] Fri, 06 June 2003 14:31 Go to previous messageGo to next message
Are you programmatically using AntRunner are just attempting to run an Ant
build?
In both cases by default the build will occur in the same VM as Eclipse...so
you must have launched Eclipse with a JRE. In 2.1 you need to launch Eclipse
with the JVM you wish to use.
In the latest integration builds and the milestone build that should be
announced later today, you can set an Ant build to run in a separate VM.
As a "normal" user: see the JRE tab for an Ant launch configuration.
Programmatically: take a look at AntLaunchDelegate.
HTH
Darins
"Dan Armbrust" <no@spam.com> wrote in message
news:bbq8v9$8jh$1@rogue.oti.com...
> Dan
Re: set java vm for ant runner? [message #65945 is a reply to message #65845] Fri, 06 June 2003 15:23 Go to previous message
Cool, thanks, I used the -vm flag on the eclipse executeable to fix it
for now.
> build?
> HTH
> Darins
>>Thanks,
>>Dan
Previous Topic:Running on RHL 7.3
Next Topic:Crash on startup under W2K Adv./W2K3 Ent.
Current Time: Fri Apr 25 01:44:18 EDT 2025
Powered by FUDForum. Page generated in 0.03186 seconds
