Re: Navigate between different diagrams [message #66757 is a reply to message #65400] |
Sat, 21 October 2006 13:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jan.herriger.gmx.de
I did, what is mentioned in
http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy
(Basic support for diagram partitioning)
The OpenDiagramEditPolicy is generated and i'm able to call the
getOpenCommand() method:
protected Command getOpenCommand(Request request) {
EditPart targetEditPart = getTargetEditPart(request);
if (false == targetEditPart.getModel() instanceof View) {
return null;
EAnnotation ann = ((View) targetEditPart.getModel())
.getEAnnotation("uri://eclipse.org/gmf/openDiagramPolicy");
if (ann == null) {
return null;
return new ICommandProxy(new OpenDiagramCommand(ann));
There is no Annotation in my model, so nothing happens here. I tried to
add an Annotation to my model, but my EMF Book doesn't seem to provide
me with the infomation I need. So i got stuck right here.
Could you provide me with some hints or even some source files?
Best regards
Jan
Jacques LESCOT schrieb:
> My problem consist of navigating between different diagrams of different
> types. I have a metamodel that I can edit through two diagram types
> (System Diagram and Automaton Diagram).
> Here is an overview of a way to associate those diagrams with objects of
> my model.
Re: Navigate between different diagrams [message #69080 is a reply to message #67567] |
Wed, 25 October 2006 11:20 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Jacques,
it works now. Actually I don't know what the problem was ;-)
The next tasks are to synchronize all opened editors instantly and to
avoid multiple opened windows of the same diagram instance.
Best regards
Jan
> Hi Jan,
> The Annotation is created in the xxx.xx_diagram file. In the
> XXXViewFactory class of the model object that you have associated with a
> diagram, the Annotation should be created.
> protected void decorateView(...)
> EAnnotation diagramFacet = EcoreFactory.eINSTANCE.createEAnnotation();
> diagramFacet.setSource("uri://eclipse.org/gmf/openDiagramPolicy");
> view.getEAnnotations().add(diagramFacet);
> Is it the case ?
> Jacques
> Jan Herriger a écrit :
>> Hello,
>> return null;
>> if (ann == null) {
>> return null;
>> to add an Annotation to my model, but my EMF Book doesn't seem to
>> provide me with the infomation I need. So i got stuck right here.
>> Best regards
>> Jan
>>> Hi,
>>> different types. I have a metamodel that I can edit through two
>>> diagram types (System Diagram and Automaton Diagram).
>>> of my model.
>>> Regards,
Re: Navigate between different diagrams [message #69554 is a reply to message #69080] |
Wed, 25 October 2006 20:01 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hello again,
is there a way to announce model changes to other opened diagrams
(without reopening)? I know, this topic has been discussed a lot, but
the only solution I found was to modify the generated code... but what
code? I had some Ideas im mind, but actually they didn't help on.
Best regards
Jan
FUDForum. Page generated in 0.03910 seconds
