| Navigate between different diagrams [message #65400] | Wed, 18 October 2006 11:48  |  |
| Eclipse User  |  |  |  |  | Hi,
 My problem consist of navigating between different diagrams of different
 types. I have a metamodel that I can edit through two diagram types
 (System Diagram and Automaton Diagram).
 Here is an overview of a way to associate those diagrams with objects of
 my model.
 Model View	-->	AssociatedDiagrams
 System		-->	SystemDiagram (the root diagram)
 -- SubSystem	-->	SystemDiagram
 -- Automaton	-->	AutomatonDiagram
 To implement that, I have generated two graphical editors. One that is
 used to edit a System (through a System Diagram), and another to edit an
 Automaton (through an Automaton Diagram). To link these two editors, in
 the gmfmap model of my System Diagram editor, I have set the "Related
 Diagrams" property of an "Automaton" to the Canvas Mapping associated
 with the gmfmap model of my Automaton Diagram editor (I expect this is
 clear until this point !).
 Then I need to change by hand the OpenDiagramEditPolicy class that was
 generated to return the DiagramKind and EditorID depending on the
 selected element (System or Automaton). Things are OK when I try to
 create a System Diagram for my Subsystem (in the above overview), but I
 can not associate an Automaton Diagram to my Automaton. The following
 Error appears :
 org.eclipse.core.runtime.CoreException: ERROR
 org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
 org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
 org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
 org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
 org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
 org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2571)
 org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2504)
 at  org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2496)
 at  org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2481)
 at  org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
 org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2476)
 org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2453)
 org.topcased.gmf.sam.system.diagram.edit.policies.OpenDiagra mEditPolicy$OpenDiagramCommand.doExecuteWithResult(OpenDiagr amEditPolicy.java:104)
 org.eclipse.gmf.runtime.emf.commands.core.command.AbstractTr ansactionalCommand.doExecute(AbstractTransactionalCommand.ja va:245)
 org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:127)
 org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
 org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:205)
 org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
 org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:155)
 org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.performRequest(GraphicalEditPart.java:1061)
 org.eclipse.gef.tools.SelectEditPartTracker.performOpen(Sele ctEditPartTracker.java:187)
 Is it possible to associate a different diagram type ? If yes, what have
 I missed ?
 Jacques
| Re: Navigate between different diagrams [message #69080 is a reply to message #67567] | Wed, 25 October 2006 07:20   |  |
| Eclipse User  |  |  |  |  | Originally posted by: jan.herriger.gmx.de
 Hi Jacques,
 it works now. Actually I don't know what the problem was ;-)
 The next tasks are to synchronize all opened editors instantly and to
 avoid multiple opened windows of the same diagram instance.
 Best regards
 Jan
 Jacques LESCOT schrieb:
 > Hi Jan,
 > The Annotation is created in the xxx.xx_diagram file. In the
 > XXXViewFactory class of the model object that you have associated with a
 > diagram, the Annotation should be created.
 > protected void decorateView(...)
 > EAnnotation diagramFacet = EcoreFactory.eINSTANCE.createEAnnotation();
 > diagramFacet.setSource("uri://eclipse.org/gmf/openDiagramPolicy");
 > view.getEAnnotations().add(diagramFacet);
 > Is it the case ?
 > Jacques
 > Jan Herriger a écrit :
 >> Hello,
 >> I did, what is mentioned in
 >> http://wiki.eclipse.org/index.php/GMF_New_and_Noteworthy
 >> (Basic support for diagram partitioning)
 >> The OpenDiagramEditPolicy is generated and i'm able to call the
 >> getOpenCommand() method:
 >> protected Command getOpenCommand(Request request) {
 >>   EditPart targetEditPart = getTargetEditPart(request);
 >>   if (false == targetEditPart.getModel() instanceof View) {
 >>     return null;
 >>   EAnnotation ann = ((View) targetEditPart.getModel())
 >>     .getEAnnotation("uri://eclipse.org/gmf/openDiagramPolicy");
 >>   if (ann == null) {
 >>     return null;
 >>   return new ICommandProxy(new OpenDiagramCommand(ann));
 >> There is no Annotation in my model, so nothing happens here. I tried
 >> to add an Annotation to my model, but my EMF Book doesn't seem to
 >> provide me with the infomation I need. So i got stuck right here.
 >> Could you provide me with some hints or even some source files?
 >> Best regards
 >> Jan
 >>> Hi,
 >>> different types. I have a metamodel that I can edit through two
 >>> diagram types (System Diagram and Automaton Diagram).
 >>> of my model.
 >>> Regards,
| Re: Navigate between different diagrams [message #69554 is a reply to message #69080] | Wed, 25 October 2006 16:01  |  |
 Hello again,
 is there a way to announce model changes to other opened diagrams
 (without reopening)? I know, this topic has been discussed a lot, but
 the only solution I found was to modify the generated code... but what
 code? I had some Ideas im mind, but actually they didn't help on.
 Best regards
 Jan
FUDForum. Page generated in 6.79064 seconds
