Re: element namespace [message #65399 is a reply to message #65377] |
Thu, 15 December 2005 15:25 |
--------------090209030405010706040508
Param,
You can use this method from XSDConstants:
public static String lookupQualifier(Node node, String namespaceURI)
You can get the node by calling XSDComponent.getElement and you can get
the namespace from XSDElementDeclaration.getTargetNamespace.
param wrote:
> Hi
> How do I get namespace prefix from each element from my Schema file
> My schema is like this
> <xstest:schema xmlns:xstest="http://www.w3.org/2001/XMLSchema">
> <xstest:element name="fromRole">
> <param:complexType>
> <xstest:sequence>
> <xstest:element name="PartnerRoleDescription">
> <xstest:complexType>
> <xstest:sequence>
> <xstest:element
> name="GlobalPartnerRoleClassificationCode" type="xstest:string"
> minOccurs="0" maxOccurs="4"/>
> </xstest:sequence>
> </xstest:complexType>
> </xstest:element>
> </xstest:sequence>
> </param:complexType>
> </xstest:element>
> </xstest:schema>
> I should get xstest , param
> Please help me How do I get.
> Advance Thanks,
> Param
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Param,<br>
<br>
You can use
Re: element namespace [message #597346 is a reply to message #65377] |
Ed Merks Messages: 33209 Registered: July 2009 |
Param,
param wrote:
> Hi
> <param:complexType>
> <xstest:sequence>
> <xstest:sequence>
> <xstest:element
> </xstest:sequence>
> </xstest:element>
> </xstest:sequence>
> </xstest:element>
> </xstest:schema>
> Advance Thanks,
> Param
<html>
<head>
<title></title>
</head>
Param,<br>
<br>
You can use
Ed Merks
FUDForum. Page generated in 0.03539 seconds
