Home » Archived » XML Schema Definition (XSD) » element namespace
element namespace [message #65377] Thu, 15 December 2005 09:20 Go to next message
How do I get namespace prefix from each element from my Schema file
My schema is like this
<xstest:schema xmlns:xstest="http://www.w3.org/2001/XMLSchema">
<xstest:element name="fromRole">
<param:complexType>
<xstest:sequence>
<xstest:element name="PartnerRoleDescription">
<xstest:complexType>
<xstest:sequence>
<xstest:element name="GlobalPartnerRoleClassificationCode"
type="xstest:string" minOccurs="0" maxOccurs="4"/>
</xstest:sequence>
</xstest:complexType>
</xstest:element>
</xstest:sequence>
</param:complexType>
</xstest:element>
</xstest:schema>
I should get xstest , param
Please help me How do I get.
Advance Thanks,
Param
Re: element namespace [message #65399 is a reply to message #65377] Thu, 15 December 2005 10:25 Go to previous message
--------------090209030405010706040508
Param,
You can use this method from XSDConstants:
public static String lookupQualifier(Node node, String namespaceURI)
You can get the node by calling XSDComponent.getElement and you can get
the namespace from XSDElementDeclaration.getTargetNamespace.
param wrote:
> Hi
> <param:complexType>
> <xstest:sequence>
> <xstest:sequence>
> <xstest:element
> name="GlobalPartnerRoleClassificationCode" type="xstest:string"
> </xstest:sequence>
> </xstest:element>
> </xstest:sequence>
> </xstest:element>
> </xstest:schema>
> Advance Thanks,
> Param
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Param,<br>
<br>
You can use
Re: element namespace [message #597346 is a reply to message #65377] Thu, 15 December 2005 10:25 Go to previous message
Param,
param wrote:
> Hi
> <param:complexType>
> <xstest:sequence>
> <xstest:sequence>
> <xstest:element
> </xstest:sequence>
> </xstest:element>
> </xstest:sequence>
> </xstest:element>
> </xstest:schema>
> Advance Thanks,
> Param
<html>
<head>
<title></title>
</head>
Param,<br>
<br>
You can use
Previous Topic:element namespace
Next Topic:Attribute vs element in XML serialization
Current Time: Tue Oct 21 20:26:22 EDT 2025
Powered by FUDForum. Page generated in 0.04812 seconds
