Re: [Gallery] ESC key no longer closes WizardDialog when Gallery added [message #65746 is a reply to message #65344] |
Thu, 16 July 2009 09:47 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Justin Dolezy![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=justin.dolezy%40digital-software-technology.co.uk) Messages: 68 Registered: July 2009 |
Member |
Nicolas Richeton wrote:
> Hi Justin,
> This is strange. To cancel normal key handling, Gallery should set
> event.doit=false somewhere. Currently this is only done if you use the
> scrolling smoother and only for mouse wheel events.
> Please check you don't have the same problem with a Canvas instead of a
> Gallery. If the problem still occurs with Canvas, open a bug on SWT,
> else, open a bug on Gallery and attach a snippet showing the problem.
Hi Nicolas,
Yes, I couldn't see anywhere in the source that's causing this, very odd.
Tried replacing the gallery with a blank canvas, and Esc is handled
correctly. I've changed my wizard, adding a ListViewer before the gallery
- this initially has focus & Esc is ok. However tabbing into the gallery
then stops Esc working...
My version of the source is a little old; will try this again once I've
refreshed.
Justin
Re: [Gallery] ESC key no longer closes WizardDialog when Gallery added [message #595698 is a reply to message #65344] |
Member |
> Hi Justin,
Hi Nicolas,
refreshed.
Justin
FUDForum. Page generated in 0.03380 seconds
