Home » Eclipse Projects » Equinox » OSGI settings missing ....
OSGI settings missing .... [message #65237] Fri, 21 April 2006 09:11 Go to next message
Hello, this is the stack after clicking on the OSGI launch configuration
icon.
!SESSION 2006-04-21 13:10:34.781
eclipse.buildId=I20060413-1718
java.version=1.5.0_04
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=fr_FR
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.core.jobs 4 2 2006-04-21 13:49:39.109
!MESSAGE An internal error occurred during: "Launching".
!STACK 0
at java.util.TreeMap.compare(Unknown Source)
at java.util.TreeMap.getEntry(Unknown Source)
at java.util.TreeMap.containsKey(Unknown Source)
org.eclipse.pde.internal.ui.launcher.EquinoxPluginBlock.retr ieveWorkspaceMap(EquinoxPluginBlock.java:236)
at .core.internal.jobs.Worker.run(Worker.java:58)
_________________________________
this clearly shows that the config for EQUINOX app is missing , but where
is it located, in which file ?
Re: OSGI settings missing .... [message #65855 is a reply to message #65237] Mon, 01 May 2006 16:35 Go to previous messageGo to next message
This looks like a bug in PDE->UI. I suggest you open a bug against that
component. Thanks.
Tom.
> icon.
> !STACK 0
> java.lang.NullPointerException
> at
> where is it located, in which file ?
OSGI settings missing ....updated [message #65954 is a reply to message #65855] Tue, 02 May 2006 13:15 Go to previous message
I have launched a simple test plugin in the framework console:
osgi> start test
org.osgi.framework.BundleException: The bundle could not be resolved.
Reason: Missing Constraint: Require-Bundle: org.eclipse.ui;
bundle-version="0.0.0"
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:294)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:239)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:145)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:293)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:278)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:213)
at java.lang.Thread.run(Unknown Source)
____________________________________________
It is as if the launcher dont know how to get the Bundle-Version
Previous Topic:org.osgi.framework.bootdelegation=*
Next Topic:setting BundleContext properties?
Current Time: Sat Mar 08 02:38:59 EST 2025
Powered by FUDForum. Page generated in 0.03491 seconds
