| Re: Programmatic new task creation from Java into Bugzilla???? [message #66273 is a reply to message #65215] |
Sun, 08 March 2009 18:10  |
Hi Vinny
recently had the same problem. I managed to figure it out by rummaging through
the code:
AbstractTaskDataHandler taskDataHandler = connector
.getTaskDataHandler();
TaskAttributeMapper mapper = taskDataHandler
.getAttributeMapper(repository);
TaskData newTask = new TaskData(mapper, repository
.getConnectorKind(), repository.getRepositoryUrl(), "");
TaskMapping taskMappingInit = new TaskMapping() {
public String getProduct() {
return "My Product";
taskDataHandler.initializeTaskData(repository, newTask,
taskMappingInit, new NullProgressMonitor());
TaskAttribute attribute = newTask.getRoot().getAttribute(
BugzillaAttribute.SHORT_DESC.getKey());
attribute.setValue("Test Bug");
BugzillaAttribute.LONG_DESC.getKey());
attribute.setValue("--- Description ---");
BugzillaAttribute.COMPONENT.getKey());
attribute.setValue("RCP Client");
client.postTaskData(newTask, new NullProgressMonitor());
Alex
Vinny schrieb am 13.02.2009 22:38:
> Sorry, this is a duplicate to my previous post but I'm not sure if this
> is the best place to post this question. Please advise if I should post
> elsewhere.
> I've used the example code at:
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.mylyn/s andbox/org.eclipse.mylyn.examples.bugzilla/src/org/eclipse/m ylyn/internal/examples/bugzilla/Main.java?root=Tools_Project &view=markup
> to query a bug report and modify a comment but I can't seem to find how
> to create a new bug from the Java API. Is the Java API fully
> functionally? I.e., can everything be done programatically that can be
> done from the Mylyn GUI? After a few days of poking around, it seems
> like the API is not fully developed.
> Can anyone show an example of how to create a NEW bug and put it into
> the Bugzilla DB from a Java program?
> I'm trying to interface with Bugzilla 3.2.2.
> Would really appreciate the help! Thanks in advance!
| Re: Programmatic new task creation from Java into Bugzilla???? [message #596597 is a reply to message #65215] |
Hi Vinny
the code:
Alex
> elsewhere.
FUDForum. Page generated in 0.05765 seconds
