Re: getText() in Text not working [message #65288 is a reply to message #65183] |
Tue, 11 December 2007 08:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: benjamin.wolff.web.de
hm, i couldn't reproduce this misbehaviour. neither on firefox 2.0.0.11
nor on IE6. when i copy something into a Text widget the getText() method
returns the proper string...
i'm using the CVS head plugins.
Antw: Re: getText () in Text not working [message #65309 is a reply to message #65288] |
Tue, 11 December 2007 09:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: admin.kabe-farben.ch
i was on IE7, but i will try on FF this evening and report back.
Andrej
>>> Ben W.<benjamin.wolff@web.de> schrieb am 11.12.2007 um 09:26 in
Nachricht
<ab4968e67fa0513c411a4bb3b611de08$1@www.eclipse.org>:
> method
Re: Antw: Re: getText () in Text not working [message #65602 is a reply to message #65498] |
Tue, 11 December 2007 14:11 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Benny
i just read Bug 192146 and there is a code snippet in it. I wouldn't know
what else to add.
Jordan writes:
"If you haven't typed, but just pasted into the text field, getText() will
return
an empty string. After you have modified the text field by typing or
deleting
some chars, everything will be fine. The problem occurs the first time
after
the text field was created."
This statement is accurate.
maybe it's the localization of the browser? i used IE7 german when this
problem occured.
Andrej
>>> Benjamin Muskalla<bmuskalla@innoopract.com> schrieb am 11.12.2007 um
13:12
in Nachricht <fjlv1k$hiq$1@build.eclipse.org>:
> this is a known bug.
> See 192146: Wrong text field behavior when using Ctrl. + V
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=192146
> The problem is that we cannot reproduce it. Just tested it with IE7 and
> FF 2.0.0.11. Maybe you can come up with a snippet how to reproduce the
> problem.
> Greets
> Benny
>> Thanks
>> Andrej
>> Nachricht
>>> method
Re: Antw: Re: getText () in Text not working [message #65770 is a reply to message #65498] |
Wed, 12 December 2007 07:20 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hi Benny
i check also with FF 2.0.0.9. Same issue as with IE7.
Greetings
Andrej
13:12
> problem.
> Greets
> Benny
>> Thanks
>> Andrej
>> Nachricht
>>> method
FUDForum. Page generated in 0.02828 seconds
