Home » Modeling » GMF (Graphical Modeling Framework) » Auto-size for nodes on a compartment with list layout
| Auto-size for nodes on a compartment with list layout [message #65165] |
Wed, 18 October 2006 09:08  |
Hi everybody,
i've got a problem with list layout. i have a node inside a compartment
(A), that is a compartment itself.
-. A .-
Im able to insert more nodes on the major compartment (now with A and B)
-. A .-
-. B .-
im using list layout to put those. But my problem is that i cant resize
them. I mean, when i insert nodes on A and B (like A.1, A.2 and B.1) i
would like them to resize automatically. Which i cant realize how to do.
-. A.1 .- <-this is the compartment A
-. A.2 .-
-. B.2 .- <-this is the compartment B
I have a figure that explain better the whole thing ->
http://www.projetos.dee.ufba.br/eln/chrome/site/list_layout. png
I hope i was clear enough, im desperate for help =)
Thanks!
Ugo
| Re: Auto-size for nodes on a compartment with list layout [message #66634 is a reply to message #66382] |
Fri, 20 October 2006 15:37   |
Hi Artem,
I tried everything, even extending FlowLayout, but it didnt worked out.
I just want the nodes to stand fixed at the upper left corner, just like
the ListLayout(which i couldnt find to extend), but with variable size.
i drawed here:
http://www.projetos.dee.ufba.br/eln/chrome/site/hiperioncad_ problem.png
can i extend the ListLayout and count how much nodes exists in the
mini-compartments so i can resize them? is that possible?
Please give me some directions on this, im lost!
i really appreciate your help
Ugo
Artem Tikhomirov wrote:
> I'd start with different layouts in NodeEditPart#setupContentPane to figure
> out which one suits you most. Perhaps, you'll need to write a custom one ;)?
> Artem
> "Ugo Sangiorgi" <ugorox@gmail.com> wrote in message
> news:ehaf56$ln6$1@utils.eclipse.org...
>> Thanks Artem,
>> in that case there are some way i could place the compartment nodes as
>> kind of "non-floating" objects?
>> Because im just using list layout so i can get this behavior.
>> Thanks for your help
>> Ugo
>>> List compartments are not suited for resizable and not-equally sized
>>> items.
>>> Artem
>>> news:eh590i$c4c$1@utils.eclipse.org...
>>>> Hi everybody,
>>>> -. A .-
>>>> -. A .-
>>>> -. B .-
>>>> -. A.2 .-
>>>> Thanks!
>>>> Ugo
| Re: Auto-size for nodes on a compartment with list layout [message #67638 is a reply to message #66634] |
Mon, 23 October 2006 06:45   |
You may try to use Grid Layout (check
https://bugs.eclipse.org/bugs/show_bug.cgi?id=133279 for details), though
it's not part of GMF yet.
Artem
news:ehb8h7$htm$1@utils.eclipse.org...
> Hi Artem,
> I tried everything, even extending FlowLayout, but it didnt worked out. I
> just want the nodes to stand fixed at the upper left corner, just like the
> i drawed here:
> Ugo
>> figure out which one suits you most. Perhaps, you'll need to write a
>> custom one ;)?
>> Artem
>>> Thanks Artem,
>>> Ugo
>>>> items.
>>>> Artem
>>>>> Hi everybody,
>>>>> compartment (A), that is a compartment itself.
>>>>> -. A .-
>>>>> B)
>>>>> -. A .-
>>>>> -. B .-
>>>>> resize them. I mean, when i insert nodes on A and B (like A.1, A.2 and
>>>>> B.1) i would like them to resize automatically. Which i cant realize
>>>>> how to do.
>>>>> -. A.2 .-
>>>>> Thanks!
>>>>> Ugo
| Re: Auto-size for nodes on a compartment with list layout [message #67842 is a reply to message #67638] |
Mon, 23 October 2006 10:05   |
Artem,
actually there are GridLayout on gmfmap, but it seems to have no effect
at all (the nodes are still loose, as they can be dragged around).
I downloaded the GridLayout and GridLayoutData, but i dont know exactly
how to apply it to the compartment.. can you point me some directions?
Thank you!
> Artem
>> Hi Artem,
>> i drawed here:
>> Ugo
>>> custom one ;)?
>>> Artem
>>>> Thanks Artem,
>>>> Ugo
>>>>> items.
>>>>> Artem
>>>>>> Hi everybody,
>>>>>> -. A .-
>>>>>> B)
>>>>>> -. A .-
>>>>>> -. B .-
>>>>>> how to do.
>>>>>> -. A.2 .-
>>>>>> Thanks!
>>>>>> Ugo
| Re: Auto-size for nodes on a compartment with list layout [message #111488 is a reply to message #67842] |
Tue, 13 March 2007 09:07  |
Originally posted by: diegobc.gmail.com
Hi everyone,
this is how I made auto-resize works on a compartment.
You'll have to edit the CompartmentNodeFigure inner class and override
the paintFigure method. It's on the CompartimentEditPart.java file.
This inner class is automatically generated and extends a class from
org.eclipse.draw2d.
This is my code for a node I'm resizing VERTICALLY so I could fit all my
objects in the compartment.
public void paintFigure(Graphics arg0) {
CompartmentNode instance = (CompartmentNode) resolveSemanticElement();
//number of nodes inside the compartment
int subNodesQuantity = instance.getSubNodes.size();
//math for new compartment height according the number of
//nodes inside it
subNodesQuantity = _EXTRA_ + (subNodesQuantity * _SUBNODE_HEIGHT_);
//setting the new object size.
this.setPreferredSize(getMapMode().DPtoLP( _WIDTH_SIZE_ ),
subNodesQuantity);
super.paintFigure(arg0);
Hope it helps.
Diego
On Mon, 2006-10-23 at 11:05 -0300, Ugo Sangiorgi wrote:
> Artem,
> Thank you!
> > Artem
> >> Hi Artem,
> >> i drawed here:
> >> Ugo
> >>> custom one ;)?
> >>> Artem
> >>>> Thanks Artem,
> >>>> Ugo
> >>>>> items.
> >>>>> Artem
> >>>>>> Hi everybody,
> >>>>>> -. A .-
> >>>>>> B)
> >>>>>> -. A .-
> >>>>>> -. B .-
> >>>>>> how to do.
> >>>>>> -. A.2 .-
> >>>>>> Thanks!
> >>>>>> Ugo
Current Time: Thu Nov 27 07:03:42 EST 2025
Powered by FUDForum. Page generated in 0.07589 seconds
