Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » validation using the org.eclipse.emf.validation.constraintProviders extension point
validation using the org.eclipse.emf.validation.constraintProviders extension point [message #65107] |
Wed, 20 December 2006 07:32 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Hallvard Traetteberg![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=hal%40ntnu.no) Messages: 673 Registered: July 2009 Location: Trondheim, Norway |
I have a constraint that applies to one kind of object (Type) which
may be attached to several kinds of other objects (Variable,
Connection and Computation). I want to evaluate the constraint
whenever this Type object is (re)attached to the relevant Variable,
Connection and Computation objects. Hence, I implemented an
AbstractModelConstraint and declared the constraint using the
extension point.
First I tried the following (notice the multiple targets):
<constraint lang="Java"
class=" no.hal.diamodl.diagram.custom.constraints.ClassTypeConstrain t "
<target class="Variable">
<event name="Set"><feature name="type"/></event>
</target>
<target class="Connection">
<event name="Set"><feature name="function"/></event>
</target>
<target class="Computation">
</target>
</constraint>
However, the constraint was never evaluated! When I split the
declaration into three constraints, each with only one target, it
worked. However, in the description of the extension point, the target
element is allowed zero, one or more times? Is this a bug or is my
understanding flawed?
Hallvard
Re: validation using the org.eclipse.emf.validation.constraintProviders extension point [message #65174 is a reply to message #65107] |
Wed, 20 December 2006 13:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hi, Hallvard,
At first blush, this looks like a bug, but that is odd because I have seen
exactly this kind of scenario work as expected in other applications (using
a model as complex as UML). I don't see anything evidently wrong with your
constraint declaration.
Would you be able to reduce the problem to a small test case that you can
attach to a bugzilla? Then I can have a closer look at it. I'm glad that
you have a work-around, for now, but it isn't nice because you don't want
users to be faced with three constraints where there should only be one ...
Christian
> extension point.
> </target>
> </target>
> </target>
> </constraint>
> Hallvard
Re: validation using the org.eclipse.emf.validation.constraintProviders extension point [message #597217 is a reply to message #65107] |
Hi, Hallvard,
Christian
> extension point.
> </target>
> </target>
> </target>
> </constraint>
> Hallvard
Current Time: Sat Aug 17 17:37:43 GMT 2024
Powered by FUDForum. Page generated in 0.03785 seconds
