Home » Archived » XML Schema Definition (XSD) » Problems with deriving types
Problems with deriving types [message #65101] Tue, 29 November 2005 12:43 Go to next message
I have a problem with extending a complexType with an attribute group.
The following types are defined:
<xs:complexType name="A">
<xs:choice minOccurs="0" maxOccurs="unbounded">
<xs:element name="source" type="element1"/>
<xs:element name="value" type="element2"/>
<xs:group ref="ns:group"/>
</xs:choice>
<xs:attributeGroup ref="ns:attributeGroup1"/>
</xs:complexType>
<xs:complexType name="B">
<xs:complexContent>
<xs:extension base="A">
<xs:attributeGroup ref="ns:attributeGroup2"/>
</xs:extension>
</xs:complexContent>
</xs:complexType>
This is part of a very large schema. When validating this schema, I get
the following error message for the type B: "The basetype has
'elementOnly' content so this extended type must also".
And indeed, when I look at the contentTypeCategory of B, it has "emtpy"
while A has a contentTypeCategory of "elementOnly". Until now I failed
to reduce the large schema to a minimal schema reproducing the problem.
Because when I reduce it only to those definition (including the
referenced definitions), the contentTypeCategory of B is also
"elementOnly", so that the error doesn't occur. Probably you have any
idea, why the contentTypeCategory of B may become "empty" sometimes?
I got the problem using XSD 2.1. Until now I had no time to test it with
more recent versions of XSD.
Cheers
Klaas
Re: Problems with deriving types [message #65126 is a reply to message #65101] Tue, 29 November 2005 13:16 Go to previous messageGo to next message
Klaas,
I suppose this could be related to
https://bugs.eclipse.org/bugs/show_bug.cgi?id=101761 but that should be
in 2.1 already. I'll have a look at the larger example if that's the
only place the problem happens...
Klaas Dellschaft wrote:
> </xs:choice>
> </xs:complexType>
> <xs:complexContent>
> </xs:extension>
> </xs:complexType>
> get the following error message for the type B: "The basetype has
> "emtpy" while A has a contentTypeCategory of "elementOnly". Until now
> I failed to reduce the large schema to a minimal schema reproducing
> the problem. Because when I reduce it only to those definition
> (including the referenced definitions), the contentTypeCategory of B
> is also "elementOnly", so that the error doesn't occur. Probably you
> have any idea, why the contentTypeCategory of B may become "empty"
> sometimes?
> with more recent versions of XSD.
> Cheers
> Klaas
Re: Problems with deriving types [message #65191 is a reply to message #65126] Wed, 30 November 2005 07:35 Go to previous message
I was able to reduce the problem to a small example. It seems to be
caused by include-statements. I opened a new bug in bugzilla
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=118621).
Cheers
Klaas
Re: Problems with deriving types [message #597245 is a reply to message #65101] Tue, 29 November 2005 13:16 Go to previous message
Klaas,
> </xs:choice>
> </xs:complexType>
> <xs:complexContent>
> </xs:extension>
> </xs:complexType>
> sometimes?
> Cheers
> Klaas
Re: Problems with deriving types [message #597269 is a reply to message #65126] Wed, 30 November 2005 07:35 Go to previous message
Cheers
Klaas
Previous Topic:Schema Validation problem with Geronimo Schemas
Next Topic:XSDConcreteComponentImpl.forceReplace throws NPE
Current Time: Fri Apr 25 19:09:48 EDT 2025
Powered by FUDForum. Page generated in 0.06405 seconds
