Outline View [message #65021] |
Mon, 24 March 2003 09:43 |
Originally posted by: cs.bcl.de
I have a large C File and the outline view does not display all keywords.
I see only the first part of the file. Is there a limitation and can I
change that ??
regards
Christoph
Re: Outline View [message #65245 is a reply to message #65021] |
Wed, 26 March 2003 14:56 |
i have relocated the problem. It is the same as described from Mr. Fabio
Frumento on 24. January. I am using the keyword "huge" in a function
declaration. When the outline parser reads that, it stops.
The same effect appears, if i delcare my own keyword using "#define".
E.g.
#define CDECL __cdecl
void CDECL myfunc() { }
regards
Christoph
Beck IPC GmbH
Christoph wrote:
> Hello,
> change that ??
> regards
> Christoph
FUDForum. Page generated in 0.04236 seconds
