Re: Copying/Cloning Annotations [message #64974 is a reply to message #64960] |
Tue, 08 November 2005 15:42 |
Dave,
Sorry, my advice to use cloneNode wasn't so good. :-(
What I think you need to do is as follows. Make sure that clonedType is
added to the xsdSchema before you try to set its annotations. Use
xsdSchema.getDocument().importNode(annotation.getElement(), true) to get
a clone that will work in the target Document. And use
clonedAnno.getElement().getParent().replaceChild(clonedAnn.g etElement(),
<result import node>). If you get stuck and have a sample project I can
run locally, I'll see what's wrong and try to make it work.
(Note that setElement is really only useful applied directly to an
XSDSchema instance; for children of the schema, their elements must be
set by the framework itself.)
Dave Carver wrote:
> When I'm serliazing the new schema, none of the annotations that I'm
> setting are showing up. I realize when you clone ConcreteComponent
> that the new component will not contain any of the annotations and you
> have to create those. However, the following code adds the
> annotations to the cloned node, but for some reason they aren't
> serialized. Here is the corresponding code:
> XSDComplexTypeDefinition clonedType =
> (XSDComplexTypeDefinition)component.cloneConcreteComponent(t rue, false);
> XSDComplexTypeDefinition type = (XSDComplexTypeDefinition) component;
> XSDAnnotation annotation = type.getAnnotation();
> if (annotation != null) {
> XSDAnnotation clonedAnno = XSDFactory.eINSTANCE.createXSDAnnotation();
> clonedType.setAnnotation(clonedAnno);
> for (Iterator it = annotation.getUserInformation().iterator();
> it.hasNext();) {
> Element docuElements = (Element) it.next();
> Element docCloned = (Element)docuElements.cloneNode(true);
> clonedType.getAnnotation().setElement(docCloned);
> This looks like it should work, any idea why the annotations aren't
> serialized with the rest of the schema.
Re: Copying/Cloning Annotations [message #597145 is a reply to message #64960] |
Ed Merks Messages: 33236 Registered: July 2009 |
Dave,
> it.hasNext();) {
Ed Merks
FUDForum. Page generated in 0.04103 seconds
