Re: BIRT Report Object Model specs update [message #65332 is a reply to message #65268] |
Fri, 05 August 2005 21:56 |
Rima Kanguri Messages: 110 Registered: July 2009 |
Scott,
The chart is implemented as a Report Item extension, therefore it is not
part of ROM specs.
We have plans to put a document describing the chart feature on the birt
website.
About FreeForm, it is not supported in 1.0, I will make the corrections in
the specs.
--Thanks
Rima Kanguri
Scott Rosenbaum wrote:
> Rima,
> Could you please explain where the ROM Spec for charting is located. I
> am probably being dense, but I don't see it in the TOC or the specs.
> Also, I see the FreeForm Element in there as since 1.0. I thought the
> FreeForm element was planned for 2.0?
> Scott Rosenbaum
> BIRT PMC
> Rima Kanguri wrote:
> >Hi,
> >The following BIRT Report Object Model specifications are updated on
> >the BIRT project website http://eclipse.org/birt/ref.
> >- ROM overview
> >- ROM base elements
> >- ROM design
> >- ROM layout
> >- ROM styles
> >- ROM scripting
> >The updates include some minor corrections based on community feedback.
> >Inconsistencies between the specifications and the 1.0,1.0.1 feature
> >descriptions have also been resolved.
> >Thanks.
> >--Rima Kanguri
FUDForum. Page generated in 0.03079 seconds
