Home » Language IDEs » AspectJ » A question about using AJDT in plugin projects
A question about using AJDT in plugin projects [message #64906] Thu, 18 May 2006 09:29 Go to next message
Originally posted by: sbederml.gmail.com
I'm working on a way of adding aspects to existing plugins. The problem is
that after importing an existing plugin as binary project with linked
content, it is not possible to add aspects to it. Though, there is no
problem when the project is imported with it sources, instead of with
linked content.
So my question is: is there a way to add aspets to binary plugin projects
with linked content?
Thank you in advance,
Michael
Re: A question about using AJDT in plugin projects [message #65022 is a reply to message #64906] Fri, 19 May 2006 08:17 Go to previous messageGo to next message
> is that after importing an existing plugin as binary project with linked
> linked content.
> projects with linked content?
It's not as straightforward, but you can do binary weaving. For example
if the plugin has its class files in a jar file called foo.jar, rename
it to say foo-orig.jar, then weave in the aspects sending the output to
a new (woven) foo.jar. You can do this manually in eclipse using a
separate AspectJ project to do the weaving in, using the inpath and
outjar settings, or you could automate the process with an Ant script.
An alternative approach would be to weave the plugin at load-time. See
for example the equinox incubator project that is looking into this:
http://www.eclipse.org/equinox/incubator/aspects/
Matt.
Re: A question about using AJDT in plugin projects [message #65043 is a reply to message #65022] Fri, 19 May 2006 22:48 Go to previous messageGo to next message
Thank you very much, Matt :)
I've managed to manually add aspects to imported plugins as binary
projects with linked content, using the following way (for
org.eclipse.search plugin):
1) Import the plugin with linked content
2) Convert the project to AspectJ project
3) Add a source folder and an aspect within it
In project properties:
4) Add org.eclipse.search.jar to AspectJ InPath
5) Set AspectJ Output jar to new jar, e.g. org.eclipse.search-weaved.jar
6) Replace org.eclipse.search.jar with org.eclipse.search-weaved.jar in
the build path
And that's it. Each weaving produces an org.eclipse.search-weaved.jar
with the added aspect, and this jar is being run.
But the problem is that I need this process to be automatic. The
problematic things is changing an AspectJ project InPath and Output jar
- is there way to do it programatically?
Michael
>> problem is that after importing an existing plugin as binary project
>> with linked content, it is not possible to add aspects to it. Though,
>> there is no problem when the project is imported with it sources,
>> instead of with linked content.
> Matt.
Re: A question about using AJDT in plugin projects [message #65234 is a reply to message #65043] Tue, 23 May 2006 15:08 Go to previous messageGo to next message
Changing those settings updates properties files under .settings in the
project, so you might be able to automate it that way. Alternatively you
could generate an Ant build file to build the project and then modify it
appropriately - such as adding options to the iajc task.
Matt.
Re: A question about using AJDT in plugin projects [message #65447 is a reply to message #65234] Fri, 26 May 2006 09:56 Go to previous message
Thank you! changing ajdt properties in .settings folder is just what I
needed.
Michael
>> jar - is there way to do it programatically?
> Matt.
Re: A question about using AJDT in plugin projects [message #593711 is a reply to message #64906] Fri, 19 May 2006 08:17 Go to previous message
> linked content.
Matt.
Re: A question about using AJDT in plugin projects [message #593756 is a reply to message #65022] Fri, 19 May 2006 22:48 Go to previous message
the build path
Michael
> Matt.
Re: A question about using AJDT in plugin projects [message #593843 is a reply to message #65043] Tue, 23 May 2006 15:08 Go to previous message
Matt.
Re: A question about using AJDT in plugin projects [message #593954 is a reply to message #65234] Fri, 26 May 2006 09:56 Go to previous message
needed.
Michael
> Matt.
Previous Topic:AJDT New Feature: New Plug-in Example
Next Topic:A question about adding AspectJ nature to a plugin project programmatically
Current Time: Wed Nov 19 14:46:14 EST 2025
Powered by FUDForum. Page generated in 0.08166 seconds
