Home » Eclipse Projects » Plugin Development Environment (PDE) » PDE build error
PDE build error [message #64901] Mon, 15 June 2009 16:40 Go to next message
Lisa Jett is currently offline Lisa JettFriend
I have tried to add the following lines to my PDE build for my application
(as per Andrew's article -
http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html):
generate.p2.metadata=true
p2.metadata.repo = file:${buildDirectory}/repo
p2.artifact.repo = file:${buildDirectory}/repo
p2.flavor = tooling
p2.publish.artifacts=true
But then I get the following error:
generate.p2.metadata:
[p2.generator] Generating metadata for
c:\build\openArbor\temp\eclipse.build\tmp\openarbor.
[p2.generator] Generation completed with success [71 seconds].
customAssembly:
[zip] Updating zip:
c:\build\openArbor\temp\eclipse.build\I.200906150921\2009061 50921-win32.win32.x86.zip
[delete] Deleting directory c:\build\openArbor\temp\eclipse.build\tmp
[p2.generator] Generating metadata for null.
BUILD FAILED
C:\ddci_eclipse\oa-lcj-workspace\com.ddci.openarbor.applicat ion\build-product.xml:91:
The following error occurred while executing this line:
C:\ddci_eclipse\oa-lcj-workspace\openarbor.pde.build\build-p de.xml:58: The
C:\Eclipse3.4.2\eclipse\plugins\org.eclipse.pde.build_3.4.1. R34x_v20081217\scripts\productBuild\productBuild.xml:31:
C:\Eclipse3.4.2\eclipse\plugins\org.eclipse.pde.build_3.4.1. R34x_v20081217\scripts\build.xml:102:
C:\ddci_eclipse\oa-lcj-workspace\openarbor.pde.build\customT argets.xml:10:
C:\Eclipse3.4.2\eclipse\plugins\org.eclipse.pde.build_3.4.1. R34x_v20081217\scripts\productBuild\allElements.xml:10:
C:\Eclipse3.4.2\eclipse\plugins\org.eclipse.pde.build_3.4.1. R34x_v20081217\scripts\genericTargets.xml:165:
c:\build\openArbor\temp\eclipse.build\package.org.eclipse.pd e.build.container.feature.all.xml:25:
c:\build\openArbor\temp\eclipse.build\package.org.eclipse.pd e.build.container.feature.all.xml:32:
An error occurred when calling generator.
Can anywone help me resolve this issue?
Lisa Jett
Re: PDE build error [message #64996 is a reply to message #64901] Wed, 17 June 2009 18:31 Go to previous messageGo to next message
Andrew Niefer is currently offline Andrew NieferFriend
Unfortunately, as you can see, that error message is not particularly
useful in figuring out what went wrong.
Try running ant with "-verbose", this should spew out huge logs and
giant stack traces. Near the end, look for a "Caused by" nested
exception coming out of
" org.eclipse.equinox.internal.p2.metadata.generator.ant.Gener atorTask.execute "
-Andrew
> application (as per Andrew's article -
> generate.p2.metadata=true p2.metadata.repo = file:${buildDirectory}/repo
> p2.artifact.repo = file:${buildDirectory}/repo p2.flavor = tooling
> customAssembly:
> [zip] Updating zip:
> BUILD FAILED
> Lisa Jett
Re: PDE build error [message #484705 is a reply to message #64996] Tue, 08 September 2009 20:00 Go to previous messageGo to next message
Chris Eagan is currently offline Chris EaganFriend
I ran into this same problem and after much frustration, I found out that
I had used 1.0.0.qualifier as the version in the .product file.
PDE Build was complaining that 1.0.0.${p2.product.qualifier} could not be
parsed. I changed the value to 1.0.0 and the build worked.
Re: PDE build error [message #484708 is a reply to message #64901] Tue, 08 September 2009 20:11 Go to previous message
Lars Vogel is currently offline Lars VogelFriend
Hi Lisa,
you find a PDE build example for 3.5 here:
http://www.vogella.de/articles/EclipsePDEBuild/article.html
PDE build has in my opinion greatly simplyfied in 3.5.
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: PDE build error [message #598371 is a reply to message #64901] Wed, 17 June 2009 18:31 Go to previous message
-Andrew
> customAssembly:
> [zip] Updating zip:
> BUILD FAILED
> Lisa Jett
Re: PDE build error [message #601356 is a reply to message #64996] Tue, 08 September 2009 20:00 Go to previous message
Re: PDE build error [message #601367 is a reply to message #64901] Tue, 08 September 2009 20:11 Go to previous message
Hi Lisa,
Best regards, Lars
Previous Topic:specifying runtime bundle-dependencies
Next Topic:eclipse plugins - external jars & environment variables - build problem
Current Time: Wed Jan 15 06:01:15 GMT 2025
Powered by FUDForum. Page generated in 0.03484 seconds
