Home » Newcomers » Newcomers » memory indicator?
memory indicator? [message #64893] Mon, 16 May 2005 14:39 Go to next message
Originally posted by: jeroen.lightyear.be
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Is there some kind of indicator in Eclipse which displays the amount of
RAM used by Eclipse?
I found two plugins that do this (by example Freemem,
http://junginger.biz/eclipse/), but today i read something about the
org.eclipse.core/perf/showHeapStatus option so i started wondering if
something like that was already included in Eclipse?
Thx!
Greetz,
Jeroen
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.1 (MingW32)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFCiOj7H04wF4t7d0oRAqKsAJ9dB2/hJZXbcYRs/V8/6KqgbQdWtwCb BD4H
aez/mOObwGprpSb6vCOYcVA=
=1KKN
-----END PGP SIGNATURE-----
Re: memory indicator? [message #65271 is a reply to message #64893] Tue, 17 May 2005 10:36 Go to previous messageGo to next message
Originally posted by: eclipse.rizzoweb.com
> Hash: SHA1
Those kinds of tools are only going to show how much heap is being used,
not the total system RAM in use. You can control Eclipse's heap usage by
specifying -Xmx and -Xms options on the eclipse.exe command-line. You
can monitor total system RAM usage through whatever tools you OS
provides. Remember that any Java process' total RAM usage is not only
the heap size but also all the other artifacts that are loaded into the
VM, including classes.
HTH,
Eric
Re: memory indicator? [message #65501 is a reply to message #65271] Tue, 17 May 2005 17:24 Go to previous messageGo to next message
Hash: SHA1
I am aware of these options and the fact that it only shows the used
heap. It's just a fancy 'nice to have'. Other applications like IntelliJ
and jEdit also have it.
While searching some more i found a nice one from the Eclipse project
itself:
http://dev.eclipse.org/viewcvs/index.cgi/platform-ui-home/de v.html?rev=1.38
(update site:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/updates)
Thx!
Jeroen
iD8DBQFCimEpH04wF4t7d0oRAojUAJ0U8+IxjcLRChAgsn8v/Mqdrff4KQCd GrIv
RvI7H6smfdYmf9NXP0fOPgo=
=a8Fw
Re: memory indicator? [message #66101 is a reply to message #64893] Wed, 18 May 2005 15:46 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
Using Eclipse 3.1 M7, create a file called ".options" in the Eclipse
install directory, containing the following line:
org.eclipse.ui/perf/showHeapStatus=true
Start Eclipse with the -debug command line argument, and you will now
see heap usage in the status line, along with a button to force garbage
collection. Clicking on the heap will "snapshot" the current heap
usage, which is useful for finding leaks and observing memory growth for
a given operation.
> Hash: SHA1
> Thx!
> Greetz,
> Jeroen
> =1KKN
Re: memory indicator? [message #66249 is a reply to message #66101] Wed, 18 May 2005 20:04 Go to previous message
Hash: SHA1
> a given operation.
Ah that's indeed a cool memory indicator :) It seems to be allmost the
same as the one found at
(but with some more options for debugging)
thx!
Jeroen
<TeRanEX/>
--- e-mail: jeroen@lightyear.be - jid: teranex@jabber.org
--- blog: http://budts.be/weblog/ - cv: http://budts.be/jeroen/
--- projects: http://lightyear.be - pgp: 0x8B7B774A
_____________________________________
NO SoftwarePatents in Europe!
See an example: http://webshop.ffii.org/
iD8DBQFCi9f3H04wF4t7d0oRAg1EAJ9qibyeJjBrn/h3Bu8VB3Vvw+j43ACf XpHp
dnZ+X3rPKJy65cGGpv5uink=
=ebfq
Previous Topic:couple of questions
Next Topic:Problems beginning Installation
Current Time: Sun Nov 02 18:59:15 EST 2025
Powered by FUDForum. Page generated in 0.08827 seconds
