| Code completion assistant [message #64851] | Mon, 21 January 2008 21:33  |  |
| Eclipse User  |  |  |  |  | Originally posted by: onkr.op.pl
 Is there a way to tell eclipse that certain variable is actually an
 object of class xyz so code completion assistant can suggest methods.
 I guess the best way to explain what I'm referring to is an example:
 //Class A and B are implementing the same interface or abstract class.
 class A extends AbstractClass{
 function method1(){...}
 function method2(){...}
 function method3(){...}
 class A extends AbstractClass {
 //Factory class
 class FAC{
 public static function Create($something){
 if($something){
 return new A();
 }else{
 return new B();
 $example = FAC::Create(1);
 Now when I use $example eclipse code completion assistant is not
 suggesting anything to me. Is there a way to tell Eclipse that the
 $example is object of class A or B?
 Ralph
FUDForum. Page generated in 0.24243 seconds
