| Re: JET2 in emft project [message #64808] | Tue, 21 July 2009 11:59 |  |
| Eclipse User  |  |  |  |  | Gloria,
 It's best to ask about JET2 on the M2T newsgroup, which I've added to
 the "to" list of the reply, so no need to repost.
 gloria guitteaud wrote:
 > Hello everybody,
 > I am working with a DSL toolkit to develop plugins. I created a Jet
 > Transformation project and I developed templates.
 > The issue deals with the "generate" method of JET2. I haven't found
 > yet a way to that method.
 > In fact,in my project, I have a folder named "templates" that contains
 > three files :dump.jet, main.jet and the template I developed. At
 > saving that files, it autogenerates classes in a folder named "jet2java".
 > I can run my template project by running the main.jet class by the
 > 'run configuration' command in the popup menu of eclipse.
 > Then, I would like to find a way to run that file without using the
 > 'run configuration' command. I think that I must use the "generate"
 > method of the class autogenerated from the main.jet template. That
 > method requires two parameter: a JET2Context and a JET2Writer. At this
 > time, I wrote the following code:("_jet_main" is the autogenerated class)
 >                _jet_main y = new _jet_main();
 >            JET2Context context = new JET2Context(null);
 >            context.setVariable("toto", y);
 >            JET2Writer out = new BodyContentWriter();
 >            y.generate(context, out);
 > Running that code, I got a null pointer exception and a link to the
 > "_jet_main" class at the following line:
 > RuntimeTagElement _jettag_c_if_25_1 =
 > context.getTagFactory().createRuntimeTag(_jetns_c, "if", "c:if",
 > _td_c_if_25_1); //$NON-NLS-1$ //$NON-NLS-2$
 > I don't really know how to use that "generate" method, but maybe I
 > don't need it finally.
 > The goal I want too reach is running the main.jet file dynamically, in
 > a class.
 > Thank's for helping me.
FUDForum. Page generated in 0.04009 seconds
