Need help creating a run configuration [message #64772] |
Wed, 19 March 2003 19:12 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: acme.us.ibm.com
When creating a run configuration, are there restrictions on what you
can set as the C/C++ Application? My project is a shared library that
gets loaded by an executable that I don't own. I need to specify the
executable that is off in a shared directory as the application, but
can't seem to get it to work. Any help would be appreciated.
Bryan
Re: Need help creating a run configuration [message #64795 is a reply to message #64772] |
Wed, 19 March 2003 21:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I figured it out. If you make a link to the executable to your project
directory, you can then access it in the run configuration.
Bryan
FUDForum. Page generated in 0.03591 seconds
