| Proper usage of diagram node selection and subsequent command processing [message #64725] | Tue, 17 October 2006 17:44  |  |
| Eclipse User  |  |  |  |  | Hi,
 due to some bug that has turned out to be quite mysterious, I would like
 to clarify some things:
 (1)
 Why get methods like e.g. PackageEditHelper.getMoveCommand(MoveRequest
 req) executed 3-5 times in a row when I do a drag'n'drop operation (with
 a single diagram element!) in my diagram?
 Not only I wonder why that method is called multiple times, but also the
 fact that the number of subsequent calls varies.
 Further, I do expect that method to be called not earlier then the
 "release mouse button event". Instead, it's called on mouse hover (with
 dragged elements glued to the mouse pointer).
 (2)
 I feel that there are some things to know concerning proper selection of
 multiple diagram nodes. In particular, how do I access the set of
 currently active diagram elements?
 (3, as a consequence of 1+2)
 When will the runtime documentation and related docs be reviewed to
 cover these nasty things?
 Thanks a lot for your advice,
 Martin Herbort
| Re: Proper usage of diagram node selection and subsequent command processing [message #64750 is a reply to message #64725] | Tue, 17 October 2006 18:39  |  |
| Eclipse User  |  |  |  |  | Originally posted by: vcciubot.uwaterloo.ca
 > (1)
 Tools/Actions etc call getCommand() on an EditPart to update the mouse
 pointer or their icon (enabled/disabled). As such, when you drag the tool
 updates the target edit part and calls getCommand() on that edit part
 which in turn calls the semantic policy which calls your edit helper.
 Those commands are checked for being executable but are only executed when
 the dragging ends.
 > (2)
 EditPartViewer#getSelection
 You can get the viewer from an edit part.
 It's hard at the beginning :)
 Some of these topics have already been covered in the GEF programmer's
 manual.
FUDForum. Page generated in 0.03701 seconds
