Home » Archived » Visual Editor (VE) » No SWT Palette / InstantiationException / SWTException (Widget is disposed)
No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #64684] Tue, 05 October 2004 06:22 Go to next message
Originally posted by: alex.NO_SPAMnightlabs.de
I have a strange problem. Two Eclipse-Plugins, both with the same build
path settings. As VE wont work without i additionally added
swt-mozilla.jar and swt-pi.jar to the build-path of BOTH projects.
Now opening Visual Editor for two equal files in these projects produces
different results. For project one everything is allright.
But in the second project Visual Editor does not display the Composite
instead a box is presented showing "this (/path/to/my/class/MyClass.java)".
A ToolTip over this box tells me : "size: org.eclipse.swt.SWTException
(Widget is disposed)"
Within the Palette all SWT entries are gone.
In the Error Log there are entries like:
ava.lang.InstantiationException: IWAV0125E "gridLayout" is too
complicated to be evaluated
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.createBeanProxy(REMStandardBeanProxyFactory.java:262)
org.eclipse.jem.internal.proxy.remote.REMAbstractBeanTypePro xy.newInstance(REMAbstractBeanTypeProxy.java:323)
org.eclipse.ve.internal.java.core.BasicAllocationProcesser.i nstantiateWithString(BasicAllocationProcesser.java:210)
org.eclipse.ve.internal.java.core.BasicAllocationProcesser.a llocate(BasicAllocationProcesser.java:149)
org.eclipse.ve.internal.java.core.BasicAllocationProcesser.a llocate(BasicAllocationProcesser.java:120)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.beanProxy Allocation(BeanProxyAdapter.java:876)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:825)
org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:755)
org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean Proxy(BeanProxyUtilities.java:338)
org.eclipse.ve.internal.java.core.BeanCellRenderer.getText(B eanCellRenderer.java:64)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.getValueAsString(AbstractPropertySheetEntry.java:722)
[snip]
OR
java.lang.InstantiationException: IWAV0125E "myData" is too complicated
to be evaluated
[snip]
ANY SUGGESTIONS ???
Thanks, Alex
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #64709 is a reply to message #64684] Tue, 05 October 2004 06:25 Go to previous messageGo to next message
Oh,
forgot to mention:
Eclipse 3.0.1 (Linux/GTK) / EMF 2.0.1 / GEF 3.0.1 / VE 1.0.1
Alex
Alexander Bieber wrote:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> [snip]
> OR
> to be evaluated
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> [snip]
> ANY SUGGESTIONS ???
> Thanks, Alex
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #64754 is a reply to message #64684] Tue, 05 October 2004 09:06 Go to previous messageGo to next message
Originally posted by: mendelgili.netscape.net
Are both UI plugins? there must be some diff.
close and open the (bad plugin) project
delete the .log, open the "bad plugin"'s file with the VE, and attache the .log.
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #65049 is a reply to message #64684] Tue, 05 October 2004 15:23 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
If you are doing plugins instead of applications (i.e. you have a
plugin.xml in your project and pre-req'd org.eclipse.swt (or ui)
plugin), then there is a bug open for this.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=74965
For now you need to add those (swt-mozilla.jar and swt-pi.jar) by hand
when you are on GTK if you are using the browser widget.
As for the other problem, I don't know. Could you please attach your
plugin.xml in the project that doesn't work, plus the class that doesn't
work so we can see if anything funny?
Rich Kulp
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #65070 is a reply to message #65049] Tue, 05 October 2004 15:58 Go to previous messageGo to next message
Just a quick note, swt-pi.jar is required even if you're not using the
browser widget. That jar contains all of the GTK-specific internal SWT
packages. The same is true when working with SWT on OS X.
- Jeff
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #65178 is a reply to message #65049] Wed, 06 October 2004 05:23 Go to previous messageGo to next message
--------------020800080002000304010008
Content-Type: text/plain; charset=us-ascii; format=flowed
Hi everybody,
thanks for the quick answers.
OK, there is a diff. The plugins do different things. The "good plugin"
is a simple UI-Plugin created with a wizard. It has one simple View.
The "bad one" defines a Product, an Application and an Extension-Point,
but it has the same plugin dependencies (plus one additional
"library-plugin" of mine wich by now only serves log4j and xerces).
> attache the .log.
..log attaced
done
Oh, by the way, is there an equivalent for JPasswordField in SWT?
OK, hope we can figure this out ...
Thanks Alex
Content-Type: text/xml;
name="plugin.xml"
Content-Disposition: inline;
filename="plugin.xml"
<?eclipse version="3.0"?>
<plugin
id="com.nightlabs.ipanema.rcp"
name="%pluginName"
version="1.0.0"
provider-name="%providerName">
<runtime>
<library name="ipanemaApp.jar">
<export name="*"/>
</library>
</runtime>
<requires>
<import plugin="com.nightlabs.base"/>
<import plugin="org.eclipse.core.runtime"/>
<import plugin="org.eclipse.ui"/>
</requires>
<extension-point
id="eventloopexceptionhandler"
name="Defines handler for EventLoopExceptions"
schema=" schema/com.nightlabs.ipanema.rcp.eventloopexceptionhandler.e xsd "
<extension
point="org.eclipse.core.runtime.applications"
id="app"
name="%appName">
<application>
<run
class="com.nightlabs.ipanema.rcp.app.IpanemaApplication">
</run>
</application>
</extension>
<extension
point="org.eclipse.ui.perspectives">
<perspective
id=" com.nightlabs.ipanema.rcp.perspective.IpanemaWelcomePerspect ive "
name="%perspectives.ipanemaWelcome.name"
class=" com.nightlabs.ipanema.rcp.plugins.perspective.IpanemaWelcome PerspectiveFactory "
fixed="true"/>
</extension>
<extension
point="org.eclipse.core.runtime.products"
id="product">
<product
name="%productName"
application="com.nightlabs.ipanema.rcp.app">
<property
name="appName"
value="%swtAppName"/>
<property
name="windowImages"
value="icons/Ipanema-Icon.gif,icons/Ipanema-Icon.gif"/>
<property
name="aboutText"
value="%aboutText"/>
<property
name="aboutImage"
value="icons/Ipanema-Logo.gif"/>
</product>
</extension>
<extension
id=" com.nightlabs.ipanema.rcp.eventloopexceptionhandler.Throwabl eHandler "
name="Exception Handler for Throwable"
point="com.nightlabs.ipanema.rcp.eventloopexceptionhandler" >
<exceptionHandler targetType="java.lang.Throwable" class="com.nightlabs.ipanema.rcp.exceptionhandler.ThrowableHandler "/>
</extension>
</plugin>
name=".log"
filename=".log"
!ENTRY org.eclipse.jem.proxy 2 0 Oct 06, 2004 11:22:26.324
!MESSAGE java.lang.RuntimeException
at org.eclipse.jem.internal.proxy.initParser.Static.evaluate(St atic.java:123)
at org.eclipse.jem.internal.proxy.initParser.InitializationStri ngParser.evaluate(InitializationStringParser.java:157)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:240)
at org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
!ENTRY org.eclipse.ve.java.core 2 0 Oct 06, 2004 11:22:26.324
!MESSAGE
+++ Warning +++: Wed Oct 06 11:22:26 CEST 2004 Could not instantiate org.eclipse.swt.widgets.Layout with initialization string=gridLayoutStatic
!ENTRY org.eclipse.ve.java.core 2 0 Oct 06, 2004 11:22:26.325
!MESSAGE Exception thrown.
!STACK 0
java.lang.InstantiationException: IWAV0125E "gridLayoutStatic" is too complicated to be evaluated
at org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.createBeanProxy(REMStandardBeanProxyFactory.java:262)
at org.eclipse.jem.internal.proxy.remote.REMAbstractBeanTypePro xy.newInstance(REMAbstractBeanTypeProxy.java:323)
at org.eclipse.ve.internal.java.core.BasicAllocationProcesser.i nstantiateWithString(BasicAllocationProcesser.java:210)
at org.eclipse.ve.internal.java.core.BasicAllocationProcesser.a llocate(BasicAllocationProcesser.java:149)
at org.eclipse.ve.internal.java.core.BasicAllocationProcesser.a llocate(BasicAllocationProcesser.java:120)
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.beanProxy Allocation(BeanProxyAdapter.java:876)
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.primInsta ntiateBeanProxy(BeanProxyAdapter.java:825)
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:755)
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.applied(B eanProxyAdapter.java:251)
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.applyAllS ettings(BeanProxyAdapter.java:537)
at org.eclipse.ve.internal.java.core.BeanProxyAdapter.instantia teBeanProxy(BeanProxyAdapter.java:757)
at org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itSetting(CompositionProxyAdapter.java:158)
at org.eclipse.ve.internal.java.core.CompositionProxyAdapter.in itBeanProxy(CompositionProxyAdapter.java:119)
at org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1488)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jem.proxy 2 0 Oct 06, 2004 11:22:26.441
!ENTRY org.eclipse.ve.java.core 2 0 Oct 06, 2004 11:22:26.442
!MESSAGE
!STACK 0
at org.eclipse.ve.internal.java.core.BeanProxyUtilities.getBean Proxy(BeanProxyUtilities.java:338)
at org.eclipse.ve.internal.java.core.BeanCellRenderer.getText(B eanCellRenderer.java:64)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.getValueAsString(AbstractPropertySheetEntry.java:722)
at org.eclipse.ui.views.properties.PropertySheetViewer.updateEn try(PropertySheetViewer.java:1123)
at org.eclipse.ui.views.properties.PropertySheetViewer.createIt em(PropertySheetViewer.java:346)
at org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf(PropertySheetViewer.java:1078)
at org.eclipse.ui.views.properties.PropertySheetViewer.access$2 (PropertySheetViewer.java:999)
at org.eclipse.ui.views.properties.PropertySheetViewer$2.childE ntriesChanged(PropertySheetViewer.java:298)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireChildEntriesChanged(AbstractPropertySheetEntry.java :373)
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:831 )
at org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1013)
at org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:805)
at org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:370)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:254)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:247)
at org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:240)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:106)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2572)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2301)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.jem.proxy 2 0 Oct 06, 2004 11:22:26.450
!ENTRY org.eclipse.ve.java.core 2 0 Oct 06, 2004 11:22:26.451
!MESSAGE
!ENTRY org.eclipse.ve.java.core 2 0 Oct 06, 2004 11:22:26.452
!STACK 0
at org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf(PropertySheetViewer.java:1099)
!ENTRY org.eclipse.jem.proxy 2 0 Oct 06, 2004 11:22:26.460
!ENTRY org.eclipse.ve.java.core 2 0 Oct 06, 2004 11:22:26.460
!MESSAGE
!ENTRY org.eclipse.ve.java.core 2 0 Oct 06, 2004 11:22:26.461
!STACK 0
at org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:807)
Content-Type: text/x-java;
name="LoginDialogStaticArea.java"
filename="LoginDialogStaticArea.java"
* Created on Oct 5, 2004
* by Alexander Bieber
package com.nightlabs.ipanema.rcp.login;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.SWT;
import org.eclipse.swt.widgets.Text;
import org.eclipse.swt.layout.GridData;
* @author Alexander Bieber
public class LoginDialogStaticArea extends Composite {
private Label labelUserID = null;
private Text textUserID = null;
private Label labelPassword = null;
private Text textPassword = null;
public LoginDialogStaticArea(Composite parent, int style, LoginConfigModule loginConfigModule) {
super(parent, style);
initialize();
private void initialize() {
GridData gridData5 = new GridData();
GridData gridData4 = new GridData();
GridLayout gridLayoutStatic = new GridLayout();
labelUserID = new Label(this, SWT.NONE);
textUserID = new Text(this, SWT.NONE);
labelPassword = new Label(this, SWT.NONE);
textPassword = new Text(this, SWT.NONE);
this.setLayout(gridLayoutStatic);
gridLayoutStatic.numColumns = 2;
labelUserID.setText("Username: ");
gridData4.horizontalAlignment = org.eclipse.swt.layout.GridData.FILL;
gridData4.grabExcessHorizontalSpace = true;
textUserID.setLayoutData(gridData4);
labelPassword.setText("Password: ");
gridData5.grabExcessHorizontalSpace = true;
gridData5.horizontalAlignment = org.eclipse.swt.layout.GridData.FILL;
textPassword.setLayoutData(gridData5);
setSize(new org.eclipse.swt.graphics.Point(214,62));
public Label getLabelPassword() {
return labelPassword;
public Label getLabelUserID() {
return labelUserID;
public Text getTextPassword() {
return textPassword;
public Text getTextUserID() {
return textUserID;
} // @jve:decl-index=0:visual-constraint="10,10"
--------------020800080002000304010008--
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #65262 is a reply to message #65178] Wed, 06 October 2004 14:56 Go to previous message
For the project that is not working it looks like you are using a JRE
level 1.4.1. For SWT beaninfo and the VE to work you need to use 1.4.2
or greater. There was a bug fixed in 1.4.2 that allowed us to do
introspection of SWT. We couldn't do it in a lower level.
Rich Kulp
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #600790 is a reply to message #64684] Tue, 05 October 2004 06:25 Go to previous message
Oh,
forgot to mention:
Alex
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> [snip]
> OR
> to be evaluated
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> [snip]
> ANY SUGGESTIONS ???
> Thanks, Alex
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #600808 is a reply to message #64684] Tue, 05 October 2004 09:06 Go to previous message
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #600890 is a reply to message #64684] Tue, 05 October 2004 15:23 Go to previous message
Rich Kulp
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #600896 is a reply to message #65049] Tue, 05 October 2004 15:58 Go to previous message
- Jeff
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #600934 is a reply to message #65049] Wed, 06 October 2004 05:23 Go to previous message
Hi everybody,
> attache the .log.
..log attaced
done
Thanks Alex
name="plugin.xml"
<plugin
name="%pluginName"
version="1.0.0"
<runtime>
<export name="*"/>
</library>
</runtime>
<requires>
</requires>
<extension-point
<extension
id="app"
name="%appName">
<application>
<run
</run>
</application>
</extension>
<extension
<perspective
fixed="true"/>
</extension>
<extension
id="product">
<product
name="%productName"
<property
name="appName"
<property
name="windowImages"
<property
name="aboutText"
<property
name="aboutImage"
</product>
</extension>
<extension
</extension>
</plugin>
name=".log"
filename=".log"
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
initialize();
return labelUserID;
return textUserID;
Re: No SWT Palette / InstantiationException / SWTException (Widget is disposed) [message #600959 is a reply to message #65178] Wed, 06 October 2004 14:56 Go to previous message
Rich Kulp
Previous Topic:New Look & Feel
Next Topic:New Look & Feel
Current Time: Wed Apr 16 03:01:28 EDT 2025
Powered by FUDForum. Page generated in 0.04966 seconds
