Home » Eclipse Projects » Plugin Development Environment (PDE) » Target Pltatform Based On Update Site
Target Pltatform Based On Update Site [message #64630] Wed, 10 June 2009 21:36 Go to next message
Chase Wolfinger is currently offline Chase WolfingerFriend
Hello - I am trying to build a target platform based on the contents of
ansoftware site. The issue I have is that packages (such as javax.sql)are
not found when I add the update site and this prohibits selecting the
plugins. If I use the plugins directly from the file system it all works
fine. Has anyone else run into this issue? I am using buckminster to
generate the update site.
Re: Target Pltatform Based On Update Site [message #64676 is a reply to message #64630] Thu, 11 June 2009 15:10 Go to previous messageGo to next message
Chris Aniszczyk is currently offline Chris AniszczykFriend
> javax.sql)are not found when I add the update site and this prohibits
> selecting the plugins. If I use the plugins directly from the file
> system it all works fine. Has anyone else run into this issue? I am
> using buckminster to generate the update site.
When you're adding the software site, there should be an option to
"Include Required Software"
If you turn that off, it should work.
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Target Pltatform Based On Update Site [message #64697 is a reply to message #64676] Thu, 11 June 2009 16:47 Go to previous message
Yes that worked. Now a second question? Is there anyway / sequence of
actions that I can execute to refresh the software site target to higher
versions. Right now I have been able to refresh by various combinations
of add / remove of the software site and eventually it refreshes the p2
metadata to pull in the next versions and I can update my target to use
these new versions - but I have yet to figure out how to do this
consistently.
Re: Target Pltatform Based On Update Site [message #598265 is a reply to message #64630] Thu, 11 June 2009 15:10 Go to previous message
Re: Target Pltatform Based On Update Site [message #598269 is a reply to message #64676] Thu, 11 June 2009 16:47 Go to previous message
consistently.
Previous Topic:Deleting a launch configuration doesnt clean up the file system data
Next Topic:Update Manager issue
Current Time: Mon Nov 18 11:23:00 GMT 2024
Powered by FUDForum. Page generated in 0.03081 seconds
