Home » Archived » BIRT » Chart - Series Grouping Key
Chart - Series Grouping Key [message #64621] Thu, 04 August 2005 08:24 Go to next message
Originally posted by: n.vibet.completel.fr
I have a problem to create a chart using a y series grouping key
for example, I have a dataset like this :
Date City Pop
2004 1 val11
2004 2 val12
2004 3 val13
2005 1 val21
2005 2 val22
I defined Date as x axis and City as a grouping key, Pop is the dataset
series for the y axis.
for Date = 2005 , there is not value (records) for City= 3: in this case,
I got errors and the chart is not generated.
Does anybody have an idea to solve this problem?
Thanks.
Re: Chart - Series Grouping Key [message #65157 is a reply to message #64621] Fri, 05 August 2005 09:13 Go to previous message
David Michonneau is currently offline David MichonneauFriend
Hi Nicolas,
This seems to be a limitation of the chart engine, please file a bugzilla
entry regarding this issue.
I think the best option for you now is to fill the missing entries in your
dataset with null values.
David
"Nicolas" <n.vibet@completel.fr> wrote in message
news:d95837705950363930f34449b4441eac$1@www.eclipse.org...
> Hello,
> I have a problem to create a chart using a y series grouping key for
> example, I have a dataset like this : Date City Pop
> 2004 1 val11
> 2004 2 val12
> 2004 3 val13
> 2005 1 val21
> 2005 2 val22
> Does anybody have an idea to solve this problem? Thanks.
Previous Topic:Sample for creating complex chart
Next Topic:Problem with property colspan
Current Time: Thu Dec 26 23:33:28 GMT 2024
Powered by FUDForum. Page generated in 0.02849 seconds
