Home » Archived » M2M (model-to-model transformation) » [ATL] Java.lang.NullPointerException with XML.ecore metamodel
[ATL] Java.lang.NullPointerException with XML.ecore metamodel [message #64581] Tue, 23 October 2007 08:24 Go to next message
I need to use the XML metamodel to convert OWL/XML files form Protege to
use them in a particular transformation. Thus I need to have the reverse
transformation of the one used in the ODM use case from G. Hillairet to
convert owl/xmi into owl/xml.
But when I try to use XML.ecore form this use case, I've got a
NullPointerException, does anybody know why ?
Guillaume Gauffre
XML.ecore :
<?xml version="1.0" encoding="ISO-8859-1"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore">
<ecore:EPackage name="PrimitiveTypes">
<eClassifiers xsi:type="ecore:EDataType" name="Boolean"/>
<eClassifiers xsi:type="ecore:EDataType" name="Integer"/>
<eClassifiers xsi:type="ecore:EDataType" name="String"/>
</ecore:EPackage>
<ecore:EPackage name="XML">
<eClassifiers xsi:type="ecore:EClass" name="Node" abstract="true">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="startLine"
ordered="false" eType="/0/Integer"/>
name="startColumn" ordered="false" eType="/0/Integer"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="endLine"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="endColumn"
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name"
ordered="false" lowerBound="1" eType="/0/String"/>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="value"
<eStructuralFeatures xsi:type="ecore:EReference" name="parent"
ordered="false" eType="/1/Element" eOpposite="/1/Element/children"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Attribute"
eSuperTypes="/1/Node"/>
<eClassifiers xsi:type="ecore:EClass" name="Text"
<eClassifiers xsi:type="ecore:EClass" name="Element"
eSuperTypes="/1/Node">
<eStructuralFeatures xsi:type="ecore:EReference" name="children"
upperBound="-1" eType="/1/Node" containment="true"
eOpposite="/1/Node/parent"/>
</eClassifiers>
<eClassifiers xsi:type="ecore:EClass" name="Root"
eSuperTypes="/1/Element"/>
</ecore:EPackage>
</xmi:XMI>
Re: [ATL] Java.lang.NullPointerException with XML.ecore metamodel [message #64672 is a reply to message #64581] Wed, 24 October 2007 03:36 Go to previous messageGo to next message
Originally posted by: quentin.glineur.obeo.fr
--------------050401030707070401070006
Hi Guillaume,
Can you send a trace of the raised exception and give more details about
the way you launch the transformation ?
Quentin GLINEUR
Guillaume Gauffre a
Re: [ATL] Java.lang.NullPointerException with XML.ecore metamodel [message #64740 is a reply to message #64672] Wed, 24 October 2007 07:36 Go to previous messageGo to next message
I changed my input model by using AM3 functionnality to inject XML
content into ecore based XML, and now it works. Do you know how to use
XML injection with both launch configuration and java code ?
Guillaume
Quentin Glineur a écrit :
> Hi Guillaume,
> Quentin GLINEUR
> Guillaume Gauffre a écrit :
>> to use them in a particular transformation. Thus I need to have the
>> reverse transformation of the one used in the ODM use case from G.
>> Hillairet to convert owl/xmi into owl/xml.
>> Thanks,
>> Guillaume Gauffre
>> XML.ecore :
>> </ecore:EPackage>
>> name="startLine" ordered="false" eType="/0/Integer"/>
>> name="endColumn" ordered="false" eType="/0/Integer"/>
>> </eClassifiers>
>> </eClassifiers>
>> </ecore:EPackage>
>> </xmi:XMI>
Re: [ATL] Java.lang.NullPointerException with XML.ecore metamodel [message #64832 is a reply to message #64740] Fri, 26 October 2007 04:47 Go to previous message
--------------090609060405010307030203
the XML injection process deals with injection (TCS) and not with
transformation (ATL). Thus, you cannot use a launch config (ATL
configuration) to perform an injection.
You can inject an XML file with an ant task (am3.loadmodel specifying an
injector) or with Java code (then look at
org.eclipse.am3.ui.ActionXMLInjector class)
Quentin GLINEUR
Guillaume Gauffre a
Previous Topic:[ATL] UML2 to UM2 transformation
Next Topic:[ATL] No KM3 editor in newest bundle
Current Time: Fri Apr 25 18:58:31 EDT 2025
Powered by FUDForum. Page generated in 0.07613 seconds
