Home » Language IDEs » PHP Development Tools (PDT) » How to disable cache of build-in web browser
How to disable cache of build-in web browser [message #64579] Wed, 16 January 2008 01:24 Go to next message
Originally posted by: alex_luya.yeah.net
I use PDT as IDE of PHP project,and the caching function of build-in web
browser is very annoy,because when I change the code,I want to get
result from it immediately,but the browser still parse old file(I think
it is cached).So,can anybody tell how to disable this cache
function.Thank you in advance.
Re: How to disable cache of build-in web browser [message #529944 is a reply to message #64579] Tue, 27 April 2010 19:09 Go to previous messageGo to next message
I have a similar problem, so I searched the forum and found this old thread. I can't believe no solution for this problem has been posted in two years! Is it really this difficult? If you know how to do it, please post :):)Smile
Re: How to disable cache of build-in web browser [message #535294 is a reply to message #64579] Fri, 21 May 2010 22:21 Go to previous message
Same here.
I found a setting that might work. It's under
Windows > Preferences > Remote Systems > File Cache
Check 'Limit cache'.
Set 'Maximum cache...' to '0'
It might work.
[Updated on: Fri, 21 May 2010 22:22] by Moderator
Report message to a moderator
Previous Topic:enable html completion in php files
Next Topic:How to set up Zend Debugger to run with URI imbedded parameter
Current Time: Thu Feb 20 19:39:13 GMT 2025
Powered by FUDForum. Page generated in 0.02945 seconds
