Problem with TPTP 4.1 and 4.2 (IWAT4039E) [message #64503] |
Wed, 05 April 2006 19:53 |
Originally posted by: thomas.olsson.in2objects.com
I have generated a test suit with the http recorder but when I try to run it
with RAC I get a:
!MESSAGE IWAT4039E The Test Execution Harness reported the following
problems:org.eclipse.core.runtime.CoreException
!STACK 1
org.eclipse.core.runtime.CoreException: IWAT4039E The Test Execution Harness
reported the following problems:java.net.ConnectException: Connection
refused:
connectorg.eclipse.hyades.internal.execution.core.file.Serve rNotAvailableException:
java.net.ConnectException: Connection refused: connect
org.eclipse.hyades.test.core.launch.delegates.AbstractLaunch ConfigurationDelegate2.launch(AbstractLaunchConfigurationDel egate2.java:178)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:590)
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:515)
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:733)
org.eclipse.debug.internal.ui.DebugUIPlugin$6.run(DebugUIPlu gin.java:931)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
!SUBENTRY 1 org.eclipse.hyades.test.core 4 0 2006-04-05 18:46:17.375
problems:java.net.ConnectException: Connection refused:
This I appearing after 66%.
I'm running against Weblogic Server with jsk 1.5.0_04.
I can connect and profile the server but not run the recording test
(generated junit test runs OK).
I've tried this both with TPTP 4.1 and the latest 4.2 release.
Has this to do with fact that I'm using jdk 5?
Is there any solution?
Many thanks
Thomas
Re: Problem with TPTP 4.1 and 4.2 (IWAT4039E) [message #67168 is a reply to message #65267] |
Thu, 20 April 2006 09:30 |
I got it to work!
The problem is that it takes 3 to 4 minutes to start the test, I don't know
what it does during that time (CPU is running at 100%). When it runs the
test
it only takes a second...
When it took that long time I thought it was something wrong and killed
Eclipse now I know it works but it takes so long for it to execute the test.
My machine is a 1.6 Ghz Pentium Mobile with 2 GB ram.
thomas
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:e1dhjm$1le$1@utils.eclipse.org...
> Hi Thomas,
> Test execution requires the Agent Controller's file server (port 10005,
> by default) to deploy the test assets. Can you confirm that the Agent
> Controller's file server is running on port 10005 and that this port is
> free? You can check the filePort attribute on the
> AgentControllerConfiguration element in the <Agent Controller's install
> directory>/config/serviceconfig.xml. If 10005 is free, please try with
> JRE
> V1.4.x. If the problem persists, please open a defect in TPTP's bugzilla.
> Paul
> "Thomas Olsson" <thomas.olsson@in2objects.com> wrote in message
> news:e1178c$qav$1@utils.eclipse.org...
>> Hi
> it
>> with RAC I get a:
>> !STACK 1
> Harness
>> refused:
> eption:
>> at
> egate2.launch(AbstractLaunchConfigurationDelegate2.java:178)
>> at
> on.java:590)
>> at
> on.java:515)
>> at
> a:733)
>> at
> eption:
>> Many thanks
>> Thomas
FUDForum. Page generated in 0.04291 seconds
