Getting Exception if using Visual Editor (Remote VM) [message #64411] |
Mon, 04 October 2004 15:04  |
Originally posted by: marco.netz.web.de
Hi *,
If I try to start the Visual Editor, for example by creating a Visual
Class, I get the following exception:
____________________________________________________________ ____________________
!ENTRY org.eclipse.jem.proxy 2 0 Okt 04, 2004 20:54:36.957
!MESSAGE IWAV0138E Remote VM terminated too soon. See .log file for
trace of output. For VM "Project (sim_traffic)-Beaninfo".
IWAV0072I Remote VM terminated before any commands can be sent.
Following are the error and output streams.
-- Error Stream --
java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(Unknown Source)
at java.net.PlainSocketImpl.connectToAddress(Unknown Source)
at java.net.PlainSocketImpl.connect(Unknown Source)
at java.net.Socket.connect(Unknown Source)
at java.net.Socket.<init>(Unknown Source)
org.eclipse.jem.internal.proxy.vm.remote.RemoteVMServerThrea d$2.run(RemoteVMServerThread.java:617)
at java.lang.Thread.run(Unknown Source)
____________________________________________________________ _____________________
I've Eclipse Version: 3.1.0, Build id: 200409240800 and using the
current version of the Visual Editor and GEF/EMF.
I'm using JRE 5.0 (Tiger) but I've tried older JRE with the same results...
I've found Bug 75108, seems the same problem...anyone an idea for a
workaround?
Thanks+ Best Regards
Marco
Re: Getting Exception if using Visual Editor (Remote VM) [message #64885 is a reply to message #64433] |
Tue, 05 October 2004 13:19  |
really don't know what the reason was, but I've restarted my PC today
(Windows XP, Service Pack 2) and now it works fine :-)).
In spite of this, thanks for your info!
Marco
Rich Kulp schrieb:
> Are you on SUSE? If you are there is a problem with the etc/hosts file.
> In the etc/hosts file, find the line that says
> ::1 localhost ...
> On this line, remove the localhost. Leave the rest of the line there.
> What happens is SUSE default installation defines localhost to be an
> IPV6 format address, and java is having problems with that.
Re: Getting Exception if using Visual Editor (Remote VM) [message #600675 is a reply to message #64411] |
Mon, 04 October 2004 15:34  |
::1 localhost ...
Rich Kulp
Re: Getting Exception if using Visual Editor (Remote VM) [message #600858 is a reply to message #64433] |
Marco
> ::1 localhost ...
FUDForum. Page generated in 0.03711 seconds
