Home » Eclipse Projects » Eclipse Platform » Centering a wizard dialog
Centering a wizard dialog [message #64356] Thu, 05 June 2003 19:44 Go to next message
Sudarshan Raghavan is currently offline Sudarshan RaghavanFriend
How do you center a wizard dialog relative to the Eclipse workbench ?? I
used the getShell().setSize() method to resize the wizard and when I use the
dialog.open() method, it splashes the dialog at different locations
everytime I open it. I tried resetting the parent shell to PlatformUI's
active workbench window shell but it doesn't seem to work.
Any thoughts ??
Sudarshan N Raghavan
Re: Centering a wizard dialog [message #64631 is a reply to message #64356] Thu, 05 June 2003 21:05 Go to previous message
Jeff Hunter is currently offline Jeff HunterFriend
Member
Sudarshan Raghavan wrote:
Override configureShell(...) and call shell.setBounds(...). You should
be able to calculate the bounds by calling getParentShell() and using
its bounds. I'm not sure if this is the best way to do it, but it works
for me.
Jeff
Previous Topic:only rebuild, no compile item in the menu
Next Topic:View arrangement question
Current Time: Thu Dec 26 13:26:20 GMT 2024
Powered by FUDForum. Page generated in 0.03182 seconds
