Home » Eclipse Projects » Eclipse Platform » only rebuild, no compile item in the menu
only rebuild, no compile item in the menu [message #64312] Thu, 05 June 2003 14:19 Go to next message
there is only "rebuild" item in the menu, sometimes,it is useful to check
the source code syntax for individual source code file.
I understand, when a new updated source code is saved, the syntax is
checked,
I am wondering if it is possible to add an menu item, like compile or some
other, when it is necessary, suppose develop a new plugin tool for some
other languang than C/C++ and Java.
Thanks.
Qhmd
Re: only rebuild, no compile item in the menu [message #64334 is a reply to message #64312] Thu, 05 June 2003 14:39 Go to previous messageGo to next message
Originally posted by: Rafael_Chaves.ca.ibm.com
Turn auto-build off (Window->Preferences->Workbench->Perform build
automatically...) and you will be able to build only when you want.
Rafael
Re: only rebuild, no compile item in the menu [message #64518 is a reply to message #64312] Thu, 05 June 2003 15:43 Go to previous message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Actually the editor, as you are typing, checks the syntax. So there is
no need to have a special build action. It will compile when saved and
tell you syntax errors while editing.
Rich
Previous Topic:Is there a way to make a call to the Eclipse Tomcat directly?
Next Topic:Centering a wizard dialog
Current Time: Thu Mar 13 14:05:54 EDT 2025
Powered by FUDForum. Page generated in 0.04160 seconds
