Home » Eclipse Projects » Remote Application Platform (RAP) » Upload a file
Re: Upload a file [message #64377 is a reply to message #64308] |
Tue, 04 December 2007 15:59 |
Originally posted by: rherrmann.innoopract.com
Christian,
you are right, RAP does not yet provide a ready-to-use file upload
widget. There is a bugzilla entry regarding this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190763
Meanwhile, have a look at the threads "File Uploader", "File Uploader
Widget" and "Uploader Widget". Does that help to get you started?
Rüdiger
Christian wrote:
> it seems that it's no possible to browse a file from client filesystem
> using something like FileDialog. My need is to browse a file and upload
> it on a server. My idea is to use a browser widget in which i load a
> jsp/servlet that manages uploading. Are there others ideas to make this job?
> Thanks
> Christian
Re: Upload a file [message #64559 is a reply to message #64514] |
Wed, 05 December 2007 09:25 |
Originally posted by: fappel.innoopract.com
thanks to Joel Oliveira there is a first implementation of file upload for
RAP available in the CVS. See the org.eclipse.rwt.widgets.upload project in
the sandbox module.
Ciao
Frank
"Christian" <zerostress@libero.it> schrieb im Newsbeitrag
news:fj4io0$94p$1@build.eclipse.org...
> thanks a lot rudiger....i'll try some alternatives from those threads..
> When do you think that a File upload widget will be available?
> Christian
> R
Re: Upload a file [message #64732 is a reply to message #64582] |
Fri, 07 December 2007 10:41 |
Originally posted by: just4lists.nospammail.net
We need to fix some questions related to external libs and the legal process
from Eclipse but we will try to have it before xmas time! _:)
Joel Oliveira
"Christian" <zerostress@libero.it> escreveu na mensagem
news:fj5sp3$ejt$1@build.eclipse.org...
> Wow,
> thanks to Joel for the christmas gift!:)
> Christian
> Frank Appel ha scritto:
>> for
>> in
>> the sandbox module.
>> Ciao
>> Frank
>>> Christian
>>> Rüdiger Herrmann ha scritto:
>>>> Christian,
>>>> Cheers,
>>>> Rüdiger
>>>> Christian wrote:
>>>>> Hi,
>>>>> upload
>>>>> this
>>>>> job?
>>>>> Thanks
>>>>> Christian
Re: Upload a file [message #65068 is a reply to message #64732] |
Mon, 10 December 2007 07:23 |
Hi Joel,
Thank you very much for your contribution on FileUpload widget. We too
need this widget badly. When can we expect this widget be released
officially (not through CVS) ?
Setya
Re: Upload a file [message #65093 is a reply to message #65068] |
Mon, 10 December 2007 08:38 |
lizzz Messages: 4 Registered: July 2009 |
Junior Member |
I impleted my File upload/download system with rap internal Browser +
servlet.
upload dialog:
public class FileUploadDialog extends TitleAreaDialog {
private Browser browser;
public FileUploadDialog(Shell parentShell) {
super(parentShell);
* Create contents of the dialog
* @param parent
protected Control createDialogArea(Composite parent) {
Composite area = (Composite) super.createDialogArea(parent);
Composite container = new Composite(area, SWT.NONE);
container.setLayout(new FillLayout());
container.setLayoutData(new GridData(GridData.FILL_BOTH));
browser = new Browser(container, SWT.NONE);
String url =
"http://"+RWT.getRequest().getServerName()+":"+RWT.getRequest().getServerPort()+ "/web/fileupload.jsp";
String html = "<?xml version=\"1.0\" encoding=\"utf-8\"
?><html><head><title>upload file</title></head><body>"+
"<form action=\""+url+"\" enctype=\"MULTIPART/FORM-DATA\"
method=\"post\"><br />File Name:</br><input type=\"file\""+
" name=\"filename\"/><br><input type=\"submit\"
value=\"upload\"/></form></body></html> ";
browser.setText(html);
setMessage("select a local file");
return area;
* Return the initial size of the dialog
protected Point getInitialSize() {
return new Point(382, 280);
protected void configureShell(Shell newShell) {
super.configureShell(newShell);
newShell.setText("upload file");
file upload sevlet:
public class FileUploadServlet extends HttpServlet {
private static final long serialVersionUID = -7245361228773015964L;
private String uploadPath = "/upload/"; // server file repository
private String tempPath = "/upload/tmp/"; //temp file folder
public void doPost(HttpServletRequest request, HttpServletResponse
response)
throws IOException, ServletException {
try {
DiskFileUpload fu = new DiskFileUpload();
// max file size
fu.setSizeMax(-1);
// buffer size
fu.setSizeThreshold(4096);
// temp path
fu.setRepositoryPath(tempPath);
// get all uploa file
List fileItems = fu.parseRequest(request);
Iterator i = fileItems.iterator();
while (i.hasNext()) {
FileItem fi = (FileItem) i.next();
// get the upload file name
String fileName = fi.getName();
String sep = System.getProperty("file.separator");
int index = fileName.lastIndexOf(sep);
if(index >-1){
fileName = fileName.substring(fileName.lastIndexOf(sep));
fi.write(new File(uploadPath + fileName));
response.getWriter().println(fileName+"upload success");
} catch (Exception e) {
//do something?
e.printStackTrace();
public void init() throws ServletException {
if (!new File(uploadPath).isDirectory())
new File(uploadPath).mkdirs();
if (!new File(tempPath).isDirectory())
new File(tempPath).mkdirs();
registe servlet:
public class HttpServiceTracker extends ServiceTracker {
public HttpServiceTracker(BundleContext context) {
super(context, HttpService.class.getName(), null);
public Object addingService(ServiceReference reference) {
final HttpService httpService = (HttpService) context
.getService(reference);
try {
//regist file upload servlet
HttpContext commonContext = new
BundleEntryHttpContext(context
.getBundle(), fileFolder);
httpService.registerResources(fileContext, "/",
commonContext);
Servlet adaptedJspServlet = new ContextPathServletAdaptor(
new FileUploadServlet(),
fileContext);
httpService.registerServlet(fileContext +
"/fileupload.file",
adaptedJspServlet, null, commonContext);
return httpService;
public void removedService(ServiceReference reference, Object
service)
final HttpService httpService = (HttpService) service;
httpService.unregister(fileContext);
httpService.unregister(fileContext + "/fileupload.jsp");
super.removedService(reference, service);
start servlet:
add these code to the bundle start up method.
public void start(BundleContext context) throws Exception {
super.start(context);
plugin = this;
httpServiceTracker = new HttpServiceTracker(context);
httpServiceTracker.open();
System.out.println("IM resource servlet started...");
Re: Upload a file [message #65206 is a reply to message #65093] |
Tue, 11 December 2007 03:21 |
Originally posted by: john_zhu.i-len.com
Hi everybody,
I've got several questions here.
1. Anyone here knows how to implement support of resume upload?
2. How to show a progress bar for the upload process?
Thank you & best regards,
John
> servlet.
> upload dialog:
> super(parentShell);
> * @param parent
> @Override
> String url =
> return area;
> @Override
> file upload sevlet:
> response)
> try {
> // max file size
> fu.setSizeMax(-1);
> // buffer size
> // temp path
> if(index >-1){
> //do something?
> registe servlet:
> try {
> commonContext);
> fileContext);
> "/fileupload.file",
> return httpService;
> service)
> start servlet:
> plugin = this;
Re: Upload a file [message #65836 is a reply to message #65068] |
Wed, 12 December 2007 10:37 |
Waiting for validation from the core RAP Team. _:)
"Setya" <jsetya@gmail.com> escreveu na mensagem
news:d908a33130c626aa4f832cc470088ee7$1@www.eclipse.org...
> Hi Joel,
> Setya
Re: Upload a file [message #65857 is a reply to message #65206] |
Wed, 12 December 2007 10:39 |
The commited upload widget (to the sandbox) already includes a parameter to
show or not a progress bar.
Joel Oliveira
"John Zhu" <john_zhu@i-len.com> escreveu na mensagem
news:fjkvog$veu$1@build.eclipse.org...
> Hi everybody,
> John
>> servlet.
>> upload dialog:
>> super(parentShell);
>> * @param parent
>> @Override
>> String url =
>> return area;
>> @Override
>> file upload sevlet:
>> response)
>> try {
>> // max file size
>> fu.setSizeMax(-1);
>> // buffer size
>> // temp path
>> if(index >-1){
>> //do something?
>> registe servlet:
>> try {
>> commonContext);
>> fileContext);
>> "/fileupload.file",
>> return httpService;
>> service)
>> start servlet:
>> plugin = this;
Re: Upload a file [message #65918 is a reply to message #65836] |
Wed, 12 December 2007 15:18 |
--------------000309000709070505000005
I am at it... but can't find a way to obtain the uploaded data.
From looking at the code, I seems to be written to a temp directory,
but within the UploadListener I don't see a way to at least obtain the
file name. Am I missing something?
Attached is the code I wrote so far. It can be run as a new tab inside
the ControlsDemo, just past the code and add
new UploadTab( topFolder )
to ControlsDemo#createContent(Composite)
Of course you need to update the plug-in dependencies to include
org...upload;)
R
Re: Upload a file [message #66132 is a reply to message #66111] |
Thu, 13 December 2007 13:22 |
Tiago,
the code I use (see attachment in my previous post) does the same as
your snippet, but doesn't work.
First of all isFinished() never returns true. But even if, according to
the JavaDoc, the getLastFileUploaded() method returns the client path
name. Besides it seems to never get assigned (Ctrl+Shift+G on
lastFileUploaded field in Upload.java)
Rüdiger
Tiago wrote:
> You can use the following snipet to get the uploaded file name:
> Upload upload = new Upload(parent, SWT.NONE, null, true);
> upload.addUploadListener(new UploadAdapter() {
> public void uploadFinished(final UploadEvent uploadEvent) {
> if (uploadEvent.isFinished()) {
> String uploadedFileName = upload.getLastFileUploaded();
> Hope it helps.
> Tiago
> "Christian" <zerostress@libero.it> wrote in message
> news:fjou7g$1on$1@build.eclipse.org...
>> i confirm the same problem.
>> Christian
>>> Hi,
>>> From looking at the code, I seems to be written to a temp directory, but
>>> within the UploadListener I don't see a way to at least obtain the file
>>> org...upload;)
>>> Cheers,
>>> Rüdiger
>>>>> Hi Joel,
>>>>> too need this widget badly. When can we expect this widget be
>>>>> released officially (not through CVS) ?
>>>>> Regards,
>>>>> Setya
Re: Upload a file [message #66219 is a reply to message #65857] |
Fri, 14 December 2007 02:18 |
Hi, Joel Oliveira:
I got it, but this widget provide only a File field for each form, I want
to send more information (such as file properties, keyword) and add multi
files dynamically, so I think I need to customize a widget. Thank you for
your answer.
John
> Joel Oliveira
>> Hi everybody,
>> John
>>> servlet.
>>> upload dialog:
>>> super(parentShell);
>>> * @param parent
>>> @Override
>>> String url =
>>> return area;
>>> @Override
>>> file upload sevlet:
>>> response)
>>> try {
>>> // max file size
>>> fu.setSizeMax(-1);
>>> // buffer size
>>> // temp path
>>> if(index >-1){
>>> //do something?
>>> registe servlet:
>>> try {
>>> commonContext);
>>> fileContext);
>>> "/fileupload.file",
>>> return httpService;
>>> service)
>>> start servlet:
>>> plugin = this;
Re: Upload a file [message #66373 is a reply to message #66219] |
Fri, 14 December 2007 10:12 |
Hi Jonh,
If possible, I would suggest something like a 2 steps approach:
- First let the user upload all the files;
- Second allow the user to tag the files with all the extra info
(properties, keywords, ...).
But if needed, you can extend this widget into a custom one.
Joel Oliveira
news:fjsp62$50t$2@build.eclipse.org...
> Hi, Joel Oliveira:
> your answer.
> John
>> to
>> Regards,
>> Joel Oliveira
>>> Hi everybody,
>>> John
>>>> servlet.
>>>> upload dialog:
>>>> super(parentShell);
>>>> * @param parent
>>>> @Override
>>>> String url =
>>>> return area;
>>>> @Override
>>>> file upload sevlet:
>>>> response)
>>>> try {
>>>> // max file size
>>>> fu.setSizeMax(-1);
>>>> // buffer size
>>>> // temp path
>>>> if(index >-1){
>>>> //do something?
>>>> registe servlet:
>>>> try {
>>>> commonContext);
>>>> fileContext);
>>>> "/fileupload.file",
>>>> return httpService;
>>>> service)
>>>> start servlet:
>>>> plugin = this;
Re: Upload a file [message #66555 is a reply to message #66132] |
Fri, 14 December 2007 17:59 |
Fixed by Tiago at CVS.
Joel Oliveira
"Rüdiger Herrmann" <rherrmann@innoopract.com> escreveu na mensagem
news:fjrbmf$164$1@build.eclipse.org...
> Tiago,
> the code I use (see attachment in my previous post) does the same as your
> Cheers,
> Rüdiger
>> Hope it helps.
>> Tiago
>>> Hi,
>>> Christian
>>>> Hi,
>>>> but
>>>> org...upload;)
>>>> Cheers,
>>>> Rüdiger
>>>>>> Hi Joel,
>>>>>> Regards,
>>>>>> Setya
Re: Upload a file [message #66927 is a reply to message #66555] |
Mon, 17 December 2007 14:28 |
--------------060009040304090706000902
in order to validate the contribution, first thing would be to get an
example to work.
With the latest code from CVS HEAD, I am still not able to get the
upload widget to work. Could you have a look at the attached snippet, a
slightly changed variant of the previous one, and tell what's wrong?
Note that uncommenting the event.isFinished() in line 42, which in my
case never returns true, doesn't solve the problem.
The use-case of the snippet is to upload an image that should be
displayed in the label below the upload widget once the "upload" button
was pressed.
R
Re: Upload a file [message #67045 is a reply to message #66971] |
Wed, 19 December 2007 23:21 |
Hi Tiago,
custom events are currently not supported by RWT. To work around this
you can wrap the event execution in a Runnable and pass it to
ProcessActionRunner#add() like this:
ProcessActionRunner.add( new Runnable() {
public void run() {
// fire event
Rüdiger
Tiago wrote:
> Hi Rüdiger,
> I've aparently located the problem. If fact there were two, some minor bug
> in the JS that was easily fixed and another one wich I'm having trouble in
> solving. It apears that at the end of my custom UploadEvent the screen is
> not "refreshed", so when you set the text or the image on the label they
> don't apear.
> Any tips regarding custom events and the lifecycle?
> Tiago
> "Rüdiger Herrmann" <rherrmann@innoopract.com> wrote in message
> news:fk613e$rqr$1@build.eclipse.org...
>> example to work.
>> was pressed.
>> Thanks,
>> Rüdiger
>>> Best regards,
>>> Joel Oliveira
>>>> Tiago,
>>>> to the JavaDoc, the getLastFileUploaded() method returns the client
>>>> path name. Besides it seems to never get assigned (Ctrl+Shift+G on
>>>> Cheers,
>>>> Rüdiger
>>>>> Hope it helps.
>>>>> Tiago
>>>>>> Hi,
>>>>>> Christian
>>>>>>> Hi,
>>>>>>> directory, but
>>>>>>> file
>>>>>>> inside
>>>>>>> org...upload;)
>>>>>>> Cheers,
>>>>>>> Rüdiger
>>>>>>>>> Hi Joel,
>>>>>>>>> Regards,
>>>>>>>>> Setya
>> * Copyright (c) 2007 Innoopract Informationssysteme GmbH.
>> * All rights reserved. This program and the accompanying materials
>> * are made available under the terms of the Eclipse Public License v1.0
>> * which accompanies this distribution, and is available at
>> * http://www.eclipse.org/legal/epl-v10.html
>> * Contributors:
>> * Innoopract Informationssysteme GmbH - initial API and implementation
>> package org.eclipse.rap.demo.controls;
>> import java.io.*;
>> import org.eclipse.rwt.graphics.Graphics;
>> import org.eclipse.rwt.widgets.*;
>> import org.eclipse.swt.SWT;
>> import org.eclipse.swt.custom.CTabFolder;
>> import org.eclipse.swt.graphics.Image;
>> import org.eclipse.swt.layout.GridData;
>> import org.eclipse.swt.layout.GridLayout;
>> import org.eclipse.swt.widgets.*;
>> final class UploadTab extends ExampleTab {
>> public UploadTab( final CTabFolder folder ) {
>> super( folder, "Upload" );
>> protected void createStyleControls( final Composite parent ) {
>> protected void createExampleControls( final Composite parent ) {
>> parent.setLayout( new GridLayout( 2, false ) );
>> final Upload upload = new Upload( parent, SWT.NONE, null, true );
>> upload.setLayoutData( new GridData( 300, SWT.DEFAULT ) );
>> final Label image = new Label( parent, SWT.NONE );
>> final Text txtDescription = new Text( parent, SWT.BORDER );
>> final Label lblDescription = new Label( parent, SWT.NONE );
>> upload.addUploadListener( new UploadAdapter() {
>> public void uploadFinished( final UploadEvent event ) {
>> if( event.isFinished() ) {
>> lblDescription.setText( txtDescription.getText() );
>> File clientFullName = new File( upload.getLastFileUploaded() );
>> image.setImage( readImage( clientFullName.getName() ) );
>> private static Image readImage( final String fileName ) {
>> Image result = null;
>> File tempDir = new File( System.getProperty( "java.io.tmpdir" ) );
>> File file = new File( tempDir, fileName );
>> try {
>> FileInputStream stream = new FileInputStream( file );
>> try {
>> result = Graphics.getImage( fileName, stream );
>> } finally {
>> stream.close();
>> } catch( IOException e ) {
>> return result;
Re: Upload a file [message #67214 is a reply to message #67153] |
Fri, 21 December 2007 15:30 |
Committed at CVS.
Best regards and happy xmas!
Joel Oliveira
"Tiago" <tiago.bugzilla@gmail.com> escreveu na mensagem
news:fkdhbs$rd1$1@build.eclipse.org...
> Hi
> Worked great! Joel will commit to the CVS the fixed version soon.
> Thanks
> Tiago
> news:fkc92m$6gl$1@build.eclipse.org...
>> Hi Tiago,
>> custom events are currently not supported by RWT. To work around this you
>> public void run() {
>> // fire event
>> Cheers,
>> Rüdiger
>> Tiago wrote:
>>> Hi Rüdiger,
>>> bug in the JS that was easily fixed and another one wich I'm having
>>> trouble in solving. It apears that at the end of my custom UploadEvent
>>> the screen is not "refreshed", so when you set the text or the image on
>>> the label they don't apear.
>>> Tiago
>>>> Hi,
>>>> example to work.
>>>> was pressed.
>>>> Thanks,
>>>> Rüdiger
>>>>> Best regards,
>>>>> Joel Oliveira
>>>>>> Tiago,
>>>>>> Cheers,
>>>>>> Rüdiger
>>>>>>> Hope it helps.
>>>>>>> Tiago
>>>>>>>> Hi,
>>>>>>>> Christian
>>>>>>>>> Hi,
>>>>>>>>> directory, but
>>>>>>>>> file
>>>>>>>>> inside
>>>>>>>>> org...upload;)
>>>>>>>>> Cheers,
>>>>>>>>> Rüdiger
>>>>>>>>>>> Hi Joel,
>>>>>>>>>>> We
>>>>>>>>>>> Regards,
>>>>>>>>>>> Setya
>>>> * Contributors:
>>>> implementation
>>>> import java.io.*;
>>>> try {
>>>> try {
>>>> } finally {
>>>> stream.close();
>>>> return result;
Re: Upload a file [message #67642 is a reply to message #67214] |
Wed, 02 January 2008 02:18 |
Originally posted by: chenmin827.126.com
On Fri, 21 Dec 2007 15:30:59 +0000, Joel Oliveira wrote:
> Committed at CVS.
> Joel Oliveira
>> Hi
>> Thanks
>> Tiago
>>> Hi Tiago,
>>> public void run() {
>>> // fire event
>>> Cheers,
>>> Rüdiger
>>> Tiago wrote:
>>>> Hi Rüdiger,
>>>> Tiago
>>>>> Hi,
>>>>> example to work.
>>>>> was pressed.
>>>>> Thanks,
>>>>> Rüdiger
>>>>>> Best regards,
>>>>>> Joel Oliveira
>>>>>>> Tiago,
>>>>>>> Cheers,
>>>>>>> Rüdiger
>>>>>>>> Hope it helps.
>>>>>>>> Tiago
>>>>>>>>> Hi,
>>>>>>>>> Christian
>>>>>>>>>> Hi,
>>>>>>>>>> directory, but
>>>>>>>>>> file
>>>>>>>>>> inside
>>>>>>>>>> org...upload;)
>>>>>>>>>> Cheers,
>>>>>>>>>> Rüdiger
>>>>>>>>>>>> Hi Joel,
>>>>>>>>>>>> We
>>>>>>>>>>>> Regards,
>>>>>>>>>>>> Setya
>>>>> * Contributors:
>>>>> implementation
>>>>> import java.io.*;
>>>>> try {
>>>>> try {
>>>>> } finally {
>>>>> stream.close();
>>>>> return result;
I have a question about upload widget: Progress bar dispalys normally when the project is lanuched in Eclipse; when the same project is deployed to Jetty composite, no progress displays when running. But no error message in this progress, and the file can be sucessfully uploaded.
Is this a known bug ?
Thanks and Regards,
cheney
Re: Upload a file [message #68111 is a reply to message #67642] |
Thu, 03 January 2008 06:52 |
> message in this progress, and the file can be sucessfully uploaded. Is
> this a known bug ?
> Thanks and Regards,
> cheney
The problems mentioned above are not bug, I have solved the problem, the
problem is: when the same project is deployed to Jetty composite,I forget
to set the upload servlet path as application context path + /upload,so the
method _processStateChange in Upload.js gets the 404 mistakes when request
the upload servlet's get method.
Thank you all the same for providing the file upload widgets.
cheney
Re: Upload a file [message #69835 is a reply to message #68111] |
Fri, 11 January 2008 14:19 |
I have a new question of the upload widget.First,I run the application with
the widget,then steps to reproduce:
1.Launch the application in Chinese version of Firefox;
2.Select a folder and click Upload;
3.Click Browse button to locate file.
Actual Result:
File Upload dialog does not appear.
Expected Result:
File Upload dialog should appear, allowing user to select file to be
uploaded.
Other Info:
The problem does not exist in English version.
Platform:
Simplified Chinese Browser: Firefox 2.0.0.6/Firefox 2.0.0.11
English Browser: Firefox_Portable_2.0.0.6/Firefox 2.0.0.11
can anyone fix the bug?
Thank and Regards,
Cheney
Re: Upload a file [message #69854 is a reply to message #67214] |
Fri, 11 January 2008 14:22 |
Actual Result:
Expected Result:
uploaded.
Other Info:
Platform:
Thank and Regards,
Cheney
Current Time: Sat Oct 19 10:55:37 GMT 2024
Powered by FUDForum. Page generated in 0.09391 seconds
