| M2 JSP Edtior no highlighting and code assist [message #64272] |
Mon, 10 January 2005 21:58  |
Originally posted by: ufel2522.ms13.hinet.net
I installed M2 version Web Tools and created a Dynamic Web Project (J2EE
Project) which associated with Tomcat 4.1.3 server.
I have three problems:
1. Every thing seems good but when i open a jsp file, no any highlight and
code assist?
2. When i create a jsp file, it showed "Updating JSP Index (Error...)"
Here is my log file:
!ENTRY org.eclipse.core.runtime 4 2 一月 11, 2005 10:55:24.181
!MESSAGE An internal error occurred during: "Updating JSP Index".
!STACK 0
java.lang.NoSuchFieldError: indexLocations
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.computeIndexLocation(JSPSearchSupport.java:453)
org.eclipse.jst.jsp.core.internal.java.search.JSPSearchSuppo rt.addJspFile(JSPSearchSupport.java:302)
org.eclipse.jst.jsp.core.internal.java.search.JSPIndexManage r$ProcessFilesJob.run(JSPIndexManager.java:212)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
3. Finally, i tried to install newest version (N2005011).
When i open a jsp file, i got a error message "Unable to create part".
!ENTRY org.eclipse.core.runtime 4 2 銝€??11, 2005 10:43:55.90
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.jdt.ui.text.JavaSourceViewerConfiguration.getAut oEditStrategies(Lorg/eclipse/jface/text/source/ISourceViewer ;Ljava/lang/String;)[Lorg/eclipse/jface/text/IAutoEditStrate gy;
org.eclipse.jst.jsp.ui.StructuredTextViewerConfigurationJSP. getAutoEditStrategies(StructuredTextViewerConfigurationJSP.j ava:111)
org.eclipse.wst.sse.ui.StructuredTextViewer.configure(Struct uredTextViewer.java:372)
org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:2379)
org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:275)
org.eclipse.wst.sse.ui.StructuredTextEditor.createPartContro l(StructuredTextEditor.java:861)
at org.eclipse.ui.internal.PartPane$2.run(PartPane.java:137)
How can i solve these problems?
thanks for your help. :)
| Re: M2 JSP Edtior no highlighting and code assist [message #64295 is a reply to message #64272] |
Mon, 10 January 2005 23:22   |
On Tue, 11 Jan 2005 02:58:35 +0000 (UTC), Bear <ufel2522@ms13.hinet.net> wrote:
The problems you mentioned sound just like those others have reported when they try to run on a 3.0x base of Eclipse. We're are strictly on 3.1 (M4). That, and the specific prereqs listed on the build page are critical.
If you confirm you have Eclipse 3.1, M4, and all the right prereqs, you might want to open a bugzilla, attaching all logs, config info, etc., (available from 'help').
Good luck. Thanks for starting early with us.
| Re: M2 JSP Edtior no highlighting and code assist [message #64361 is a reply to message #64295] |
Tue, 11 January 2005 03:02  |
Thanks for your help :)
I solved my problem!
Web Tools Platform cool!!
Expect release version sincerely.
FUDForum. Page generated in 0.03208 seconds
