Startup problem on Windows [message #64247] |
Wed, 05 May 2004 14:48 |
Originally posted by: armaz.uninett.no
I hope this is the right place to post this. I cant start Eclipse om my
computer and CAN'T find any similar problem posted on these mailing lists.
Here is what I get in the .log file, right after I try to start it :
!SESSION ------------------------------------------------------------ -------
!ENTRY org.eclipse.core.launcher 4 0 mai 05, 2004 16:22:35.807
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.reflect.InvocationTargetException:
java.lang.reflect.InvocationTargetException: java.lang.NullPointerException
java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object,
java.lang.Object[])
native code
java.lang.Object
org.eclipse.core.launcher.Main.basicRun(java.lang.String[])
Main.java:291
java.lang.Object org.eclipse.core.launcher.Main.run(java.lang.String[])
Main.java:747
void org.eclipse.core.launcher.Main.main(java.lang.String[])
Main.java:583
Any suggestion what to do or where to search ? Is the source code available
to see what happens on line 291 on Main.java ??
I have tried both 2.1.3 and 2.1.2. Same problem with both of them. It is
very fishy that only I should have this problem :(
Thanks in advance
FUDForum. Page generated in 0.03793 seconds
