[ATL] ASMModul not found in ATL 2.0 [message #64243] |
Thu, 18 October 2007 12:02 |
Hi all,
I'm using ATL programmatically by using a Java class based on Denis
Waagelar's command line tool (see
http://ssel.vub.ac.be/svn-gen/UML1CaseStudies/uml1cs-atlcomm andline/src/org/atl/commandline/Main.java).
This
code uses org.atl.engine.vm.nativelib.ASMModel and
org.atl.engine.repositories.emf4atl.ASMEMFModel. With ATL Version 1.0,
the code compiled, but with ATL 2.0. both classes are not found. Of
course the package names were changed, but these classes are not found
anymore. ASMModel is now found in plugin
org.eclipse.m2m.atl.engine.vm_2.0.0. My plugin defines this plugin as a
required plugin, but apparently the classes of this plugin are not
found. The same is true for ASMEMFModel, which is now found in plugin
org.eclipse.m2m.atl.drivers.emf4atl_2.0.0.
As far as I understand the manifest files, the classes are exported. Is
it possible that a plugin cannot use classes of another plugin which
are not part of a jar? Did anyone else found the same problem, too?
Jens
Re: [ATL] ASMModul not found in ATL 2.0 [message #64399 is a reply to message #64243] |
Mon, 22 October 2007 14:12 |
William Piers Messages: 301 Registered: July 2009 |
--------------060400080506050307060200
Content-Type: text/plain; charset=UTF-8; format=flowed
There may be a bug into the exported plugins, you can submit it on this
page :
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=M2M
When I test with the source plugins it works. So you can try to :
1) get ATL source code for emf4atl and vm plugins
2) export them into jar files
3) use these jars as libraries into your commandline plugin
Of course it is a temporary solution, waiting for a best solution.
William Piers
Jens v.P. a écrit :
> Hi all,
> This
> it possible that a plugin cannot use classes of another plugin which are
> Jens
Content-Type: text/x-vcard; charset=utf-8;
name="william.piers.vcf"
Content-Disposition: attachment;
filename="william.piers.vcf"
YmVnaW46dmNhcmQNCmZuOldpbGxpYW0gUGllcnMNCm46UGllcnM7V2lsbGlh bQ0Kb3JnOk9i
ZW8NCmFkcjoyIHJ1ZSBSb2JlcnQgU2NodW1hbm47O2xvdCAyNDtOQU5URVM7 OzQ0NDA4O0Zy
YW5jZQ0KZW1haWw7aW50ZXJuZXQ6d2lsbGlhbS5waWVyc0BvYmVvLmZyDQp0 aXRsZTpNREEg
Q29uc3VsdGFudA0KdGVsO3dvcms6KzMzICgwKTIgNTEgMTMgNTEgODINCnRl bDtjZWxsOisz
MyAoMCk2IDIwIDMxIDc1IDk4DQp1cmw6aHR0cDovL3d3dy5vYmVvLmZyDQp2 ZXJzaW9uOjIu
MQ0KZW5kOnZjYXJkDQoNCg==
--------------060400080506050307060200--
FUDForum. Page generated in 0.03795 seconds
