Starting ANT with keyboard shortcut [message #64241] |
Sun, 22 June 2003 04:11  |
Originally posted by: david.purple-sunshine.de
I've posted this before but received no answer, so I'll try it again -
sorry for reposting: is there any way I can start ANT with a keyboard
shortcut?
I have tried it with Windows/Preferences/Workbench/Keys but can't find
any way to start ANT there. Currently, I have to do Run/External
Tools/Run As/Ant Build to get what I need - which is a rather deep menu
link. Alternatively, I could use the context menu of build.xml - which
is much better but still a lot more than e.g. hitting F9.
Auch das geht vorüber. (Sufi-Weisheit)
Holger (David) Wagner Tel: +49 (89) 890 50 962
Dewetstrasse 1 Mobil: +49 (177) 274 12 45
D-80807 München Fax: +49 (177) 992741245
Re: Starting ANT with keyboard shortcut [message #70977 is a reply to message #70836] |
Tue, 01 July 2003 11:30  |
Feature requests / enhancements are initiated with bug reports.
Darins
"Holger (David) Wagner" <david@daten-raum.de> wrote in message
news:3F0165BB.8050502@daten-raum.de...
> Darin Swanson wrote:
> > Please log a bug report for this enhancement with how you would see this
> > feature working
> Wouldn't this typically be a feature request?
> thanks,
> david
> > Thanks
> > Darins
> > news:bd6dd0$rru$1@rogue.oti.com...
> >>Hi Jochen,
> >>Jochen Vogele wrote:
> >>>Hai David,
> >>>AFAIK there is no direct shortcut for ant, but i defined a key for "Run
> > Last
> >>>Launched External Tool" (eg F9 :). So after starting ant the first
time,
> > you
> >>>only have to press F9 th next time you want to run your ant-build.
> >>>Hope it helped to make your life a little easier ;)
> >>Thanks a lot! This may not be a perfectly smooth solution - but it's a
> >>very handy workaround! Hope they'll integrate ANT better soon...
> >>regards,
> >>david
> >>Auch das geht vor
FUDForum. Page generated in 0.08725 seconds
