Eclipse 3.0.2 could not start on the ext filesystem [message #64120] |
Sat, 14 May 2005 02:56 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: xiejw217.yahoo.com.cn
I downloaded the version : eclipse-SDK-3.0.2-linux-gtk.zip ,but always
fail to start it in the linux platform.
The details :
** Linux : Debian sarge
** Java VM :
$java -version
java version "1.4.2_06"
Java(TM) 2 Runtime Environment, Standard Edition (build 1.4.2_06-b03)
Java HotSpot(TM) Client VM (build 1.4.2_06-b03, mixed mode)
** Start the eclipse on the ext filesystem :
xiejw:/usr/local/share/eclipse# ./eclipse
org.osgi.framework.BundleException: Unable to find system bundle manifest
file.
org.eclipse.osgi.framework.adaptor.core.SystemBundleData.cre ateManifest(SystemBundleData.java:73)
org.eclipse.osgi.framework.adaptor.core.SystemBundleData.<init >(SystemBundleData.java:34)
org.eclipse.osgi.framework.adaptor.core.AbstractFrameworkAda ptor.createSystemBundleData(AbstractFrameworkAdaptor.java:29 4)
org.eclipse.osgi.framework.internal.core.SystemBundle.<init >(SystemBundle.java:41)
org.eclipse.osgi.framework.internal.core.Framework.createSys temBundle(Framework.java:187)
org.eclipse.osgi.framework.internal.core.Framework.initializ e(Framework.java:152)
org.eclipse.osgi.framework.internal.core.Framework.<init>(Framework.java:95)
org.eclipse.osgi.framework.internal.core.OSGi.createFramewor k(OSGi.java:90)
org.eclipse.osgi.framework.internal.core.OSGi.<init>(OSGi.java:31)
org.eclipse.core.runtime.adaptor.EclipseStarter.startup(Ecli pseStarter.java:215)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:127)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
I can see the splash window, but the start crashed immediately.
Pay attention to the first warning:
"org.osgi.framework.BundleException: Unable to find system bundle manifest
file"
As discussed in another newsgroup, the bundle file
"eclipse/configuration/org.eclipse.osgi/.bundledata" disappeared when the
eclipse needs to read it.
However, after i mount a fat32 filesystem volumn and start the same
version on it, eclipse starts successfully.
How could i solve this problem?
Re: Eclipse 3.0.2 could not start on the ext filesystem [message #64143 is a reply to message #64120] |
Sat, 14 May 2005 05:36 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
I have found what the problem is.
It should be that unzip the .zip file on the ext filesystem, not the
fat32's one.
At the first time, for convenience, I unzip it under the WinXp, then
switch the opration system and move all the files from the fat32 to the
ext. Maybe this is the major problem .
FUDForum. Page generated in 0.08037 seconds
